2022 Xpedition Voyager South Carolina
ROA-OFFROAD
Supporting Sponsor / Approved Vendor
Super clean Xpedition Voyager loaded with options for sale! Ready to roll! The only thing it doesn’t have is a fridge! More pics coming soon.
Price is 43,997
Duncan, SC
iKamper X-Cover with annex, awning, winter insulation kit, upgraded mattress
2,000 watt inverter
2x Lithium Battle Born Batteries
Redarc management system
23zero shower enclosure
10″ Brooklyn bedding memory foam full XL mattress
270 degree awning
Some Specs-
  • Gross Weight Rating : 4200lbs
  • Base Trailer Dry Weight: 2600lbs
  • Overall Length: 192”
  • Overall Width: 89”
  • Overall Height: 82”
  • Ground Clearance: 18”
  • Track Width: 76”
  • Suspension Travel 4.5″
  • Interior Length: 86.5”
  • Interior Width: 55.5″
  • Interior Height: 48″
  • Mattress Size: 53” X 75″-80”
  • Freshwater Capacity: 36gal
  • Roof Rack: 94” X 58″
  • All metal construction, no wood to rot or mold.
  • Aircraft grade engineering with 99% of components manufactured from aluminum. Apart from the tongue, suspension, and bumper/hitch (which are steel) the Voyager trailer is manufactured entirely of aluminum and stainless steel. This gives you the benefit of higher strength, light weight, and fantastic corrosion resistance.
  • 1/8” Aluminum Exterior shell construction including roof
  • ¼” Aluminum Base Plate
  • All joints are secured by ultra-high strength mechanical fasteners using special tooling capable of ensuring a proper connection 100% of the time.
  • In-house engineered & manufactured Independent A-Arm X-Ride Suspension (2023 Model)
  • Extreme off-road jack
  • 360 degree Maxcoupler Hitch (Receiver and Tow Vehicle Adapter)
  • Dual Side doors with operating windows and screens (26” X 36”)
  • 2 3/16” insulated walls
  • Roof rack with 6 cross rails (94″ X 58″)
  • Extruded Polystyrene Rigid Foam Insulation that is moisture resistant and boasts the following certifications:
CharlieGreenT
