2024 Entegra ACCOLADE XT 29T 4X4 Diesel with Buckstop conversion $229K
Rlemond
2024 Entegra Coach Accolade XT Super C 29T. Complete Buckstop Super Single wheel conversion done. $30K value. Includes 3.5" Suspension lift kit with Radflo remote reservoir shocks and 41" Continental 335/80/R20 tires. 7K PRO HD - D.O.T. COMPLIANT – 100% made in USA Forged aluminum wheel. Precision machined, top quality and designed for military tires. Rated to 7,390lb weight capacity. Gross Vehicle Weight Rating (lbs)19,500. Gross Combined Weight Rating (lbs)31,500.
Air Conditioning15,000 BTU A/C unit with heat pump and second 13,500 BTU A/C unit
Inverter2,000W pure sine wave inverter
Solar200W solar panel with dual controller
Generator6,000W diesel generator and auto-gen start
Batteries(2) 6V AGM house batteries
Transfer SwitchTransfer switch with reverse polarity protection
Electrical Hookup50-amp service
Propane24.5 gal. propane tank (83 lb.) with LP quick-connect hookup
Winterization Drain SystemWinterization drain system
Tank FlushOutside shower and black tank flush
Water Pump12V demand water pump
Water FiltrationWater filtration system
Heating System30,000 BTU auto-ignition furnace
Water Heater10 gal. gas/electric water heater
Ford F550 Chassis with 6.7 Powerstroke Diesel engine and 10 Speed transmission. Front Gross Axle Weight Rating (lbs)7,000. Rear Gross Axle Weight Rating (lbs)14,706. Exterior Length 29' 10" Exterior Height with A/C and Satellite 12' 6" . Interior Height 7' 0". Fresh Water Capacity (gals)72. Grey Waste Water Capacity (gals)43. Black Waste Water (gals)43. Fuel Tank Capacity (gals)67. Furnace (BTU Output)30,000 BTU auto-ignition Wheel Base 205"
Link to Buckstop Super single wheel conversion. https://www.buckstopinc.com/single-wheel-conversions.html#overview
Please contact me with any questions. Has about 12K miles on it but will come with a manufactures warranty.
Email. rodlemond@hotmail.com
Text or call 714-260-8262 Screenshot 2025-01-08 111228.pngScreenshot 2025-01-08 111324.pngScreenshot 2025-01-08 111449.pngScreenshot 2025-01-08 111722.pngScreenshot 2025-01-08 111847.pngScreenshot 2025-01-08 112007.pngScreenshot 2025-01-08 112117.pngScreenshot 2025-01-08 112245.pngScreenshot 2025-01-08 112320.pngScreenshot 2025-01-08 112423.png
sunnyaz
