2024 F-350 aluminum bed
Oyster9
Started on bulb seals for the doors.
Mitered the corners on a bandsaw then glued with black contact adhesive.
Difficult to cut true and get a good tight joint.
After the first one, aborted the mitered joints and opted for lap joints.
The boxes have vents and drains to help keep dry.
Oyster9
Finished fitting up the door seals, gluing and screwing the hinges, lubing and adjusting the latches, tacking the ears for cable door stops. The end is in sight.
xander69
