2024 Ford F250 Super Duty Water Tank Ideas
kramcutthroat
As the title states I am currently building a 24 f250 SD and want to install a water tank for domestic water. I am trying to figure out something that can be mounted under the vehicle, preferably where the spare would go. I see there is a tank like this for the ford transit and I am curious if that might work for my use or if anyone knows of any other products that might work. Doesnt have to be where the spare is but I dont need that spare so it would be a great spot for it. Not opposed to mounting it other places under the truck if anyone has any ideas. Thanks in advance!
carterd
You might consider a Titan spare tire auxiliary fuel tank. There is probably some additional filtration needed as this is not rated for potable water.
andy_b
By mounting it outside the conditioned envelope of the camper, you’ll have to ensure it doesn’t freeze or get melted by the exhaust. Why not just put it inside? Weight distribution will be better low and in front of the rear axle, too.
At any rate, I had a tank made by Trionic and they could probably make something for you, too.
V45W_Proto2.5
