2024 Toyota Tundra Four Wheel Campers Project M Overland Build - $75,000
fwc_tundra
2024 Toyota Tundra CrewMax, 4x4, Sr5 with the TRD Off Road Package (rear locker). Blueprint blue exterior, black interior. About 7k miles on the truck, work was done with 3k miles on the truck. All work is invoiced from reputable builders.
RPM Build - $29,140.25
  • King 2.5 Front Coilovers with resi and adjuster
  • King 2.5 Rear Shocks w/ resi and adjuster
  • Total Chaos UCA
  • Old Man Emu Rear Springs (880 lb static weight)
  • Icon Diff Drop
  • Timbren Front/Rear Active Off Road Bump Stops
  • King Rear End Links
  • Toyo R/T Trail 35/12.5x17
  • Volk Racing TE37XT M-Spec in Arms Gray
  • Titan Lug Nuts and Wheel Locks
  • Labor for wheel/tire clearance
  • C4 Front Bumper
  • Baja Design S8 40’ Amber Light Bar
  • Baja Design SAE Fogs in Amber
  • Warn Evo 12-S Winch
  • Factor 55 Fairlead
  • Factor 55 Ultrahook
  • C4 Sliders
  • Baja Design Rear Chase Lights in Amber
  • Rago Bed Stiffeners
  • S-Pod BantamX
  • Wifey Air System
  • ARB Dual Compressor
  • SDHQ Compressor Mount
Project M - $19,095.30/Al Build out - $15,670
  • Insulation Package
  • Interior/Exterior mounting tracks
  • 2 interior fans
  • Large Passenger and Driver window
  • Roof rails
  • Solar panel
  • Full interior build
  • Outlets
  • Sink w/ water pump, water filter, 10 gallon fresh water tank
  • Microwave
  • Full Read Arc solar management
  • Dakota Lithium 315ah battery
  • Mule Awning Mounts
  • Roverroll 270 degree Awning
Additional Parts
  • Exterior and Interior camper molle panels
  • Midland Radio
  • Mountain Hatch
  • FWC Bug Net
  • FWC Quick Attach Hose
fwc_tundra
More images
Nepali
Are you selling both the tundra and camper for $75,000? Is it still available! Are you in California? Was the work done to upgrade the pick up for the camper?
George Hochstetler
fwc_tundra
George Hochstetler
Hi - yes, the camper and truck for the price of $75k. It is still available and I am in CA. Truck and camper are built up with all quality parts and partner perfectly together. This is good to go.
Nepali
Thank you. What is the height from the ground to the very top of whether it’s a solar panel or vent on top of the camper? I have 93 inches to work with.
sunnyaz
