Thread: 1998 Infiniti QX4
  1. #1
    Join Date
    Dec 2008
    Location
    Florida Panhandle
    Posts
    100
    Default 1998 Infiniti QX4
    My buddy has a 1998 Infiniti QX4.
    What do you think of this vehicle? What are it's stock capabilities?
    His vehicle also has demolished rear shocks and stock replacements are coming to $40 a piece. What are some upgraded shocks that are similar in price? This vehicle spends almost all of it's time on road so he doesn't need anything extreme, but we destroyed the stock ones way to fast.
  2. #2
    Join Date
    Aug 2005
    Location
    Calgary, Canada
    Posts
    3,884
    Basically the same truck as the Pathfinder. With a good set of tires, it's actually quite capable offroad. The 98's had the the All Road 4WD system that had a low range plus a "Lock" setting. That setting locked the center diff and put 50% power to both front and rear. On the other settings it varied front to rear depending on wheel slippage.
    I think there was an optional limited slip rear diff too. This is really pulling from the depths of my memory here, but I think if there was an orange sticker on the diff it had the limited slip.
    Also pulling from even further depths of the memory, you should be able to squeeze 31" BF AT tires in there without a lift and only mild rubbing in the rear during flex.
    Pete
    Pete Hartl - VE6PGH - 0VRLAND
    EXPEDITION = (Encounters + Adventures + Experiences) x YOU
  3. #3
    I own a 99 QX4 and they are pretty nice vehicles. Just a fancy R50.
    Up to 2000, same 3.3 engine and Auto as in the pre 05 Xterra and Frontiers.
    The ATX14A transfer case that came in these vehicles seems to be pretty decent. The low range is lower than the standard TX10 at around 2.4:1 vs 2:1. I could tell a difference between my 99QX4 and 98Pathfinder before I put the low range gears in the Pathfinder.
    the 98 should have the knob for 2wd, all wheel drive and 4 wheel high (center diff lock), then a lever for 4 low. Most of the Qs came with LSDs in the rear.
    No major issues, but I really wouldn't go to 31" tires without some lift springs. This vehicle would be great for fire roads, dirt roads, light offroading, and snowy pavement roads. The all mode all wheel drive is pretty nice.
    Upgrade options:
    Locker rear - ARB
    Locker Front -ARB (use the one for the R200, even though the R50s have a high pinion R200 up front it works)
    Gears lowest - 4.64, could go lower but the front High pinion R200 is the limit, can get 5.14s for the rear.
    Rear end is the 33 spline with drums
    Lift springs - 4x4parts.com up to two inches
    Custom drop lift - built them, pretty straight forward
    To give a point of reference I would drive this vehicle on any of the trails in the Ouray, CO area except Poughkeepsie (sp).
    Also, I could be wrong, but a locked diff will distribute 100% power to all outputs.
  4. #4
    Join Date
    Jan 2007
    Location
    Central PA
    Posts
    216
    If they are stock, and possibly original, they are probably beat just from being 10+ years old. Does the vehicle have a tow history? Your coils may be worn as well - they just wear out early on these rigs. My preference is Old Man Emu shocks and coils (used to have a '97 pathy) but if you want low price just run Nissan. the shocks have a marginal effect on performance - the coils are what carry the load and determine if you're bottoming out.
    4 wheels:
    2010 Tundra Crewmax / OME suspension / Slee sliders / BudBuilt skids / TRD wheels / 34x10.5/17 BFGs / Leer 180 cap
    2 wheels:
    2003 Honda 50
    2008 KLR650
    2007 Honda ST1300
    Surly ECR
    Fisher Rumblefish
    www.purplelizard.com
  5. #5
    100% correct about the rear end, it is the springs. My 99 bottoms like crazy due to saggy coils. I have replaced the shocks numerous times with no effect on the ride.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
