Fuso with custom Alaskan Camper popup
haven
Alaskan Camper (www.alaskancamper.com) has sold popup truck campers
for many years. Their popup has hard walls, rather than the canvas used by
4 Wheel Camper, Hallmark, Arctic Fox, and many others. The company
builds popups with cab-over for standard pickups, and they build models
without cab-over for other applications.
The hard walls and solid construction make the Alaskan Camper models
heavy for their size, but they are well-built and durable. The
mechanism that raises and lowers the popup roof is hydraulic, powered by
an electric pump.
Alaskan Camper advertises on their web site that they can custom build a
camper to your specifications. I wrote to Alaskan Camper to ask if
they could build a 14ft long version to mount on a Fuso FG 4x4 chassis.
I promptly received this reply:
"It's something we can do. We're building a 13ft on a Dodge Sprinter.
The camper on the Fuso pictured on our website is a 12ft custom model.
Bryan Wheat, alaskan@alaskancamper.com"
Here's the abovementioned 12ft camper, on a short wheelbase Fuso FG:
This setup is attractive. The SWB Fuso has a turning circle that,
at 38 ft, is only a foot larger than the standard cab Tacoma. The
SWB also increases breakover angle. Modify the rear bumper on the
vehicle pictured to increase departure angle, and you've got a very
capable rough-road adventure camper.
The Alaskan Camper is a close match to the dimensions of the
Fuso:
Fuso FG width, at cab ...................... 79 inches
Alaskan Camper width, outside ........... 84 inches
The Alaskan Camper is a lot narrower than the typical
North American truck camper, which usually measures 95 inches.
84 inches is narrow enough to fit through the door of a shipping
container when you need to transport the camper overseas.
(The Fuso, at 96 inches tall at the cab with tires fully inflated, requires
a high-top shipping container. )
Fuso FG height, top of frame to top of cab .... 60 inches
Alaskan Camper height, top retracted .......... 61 inches
When mounted on the long wheelbase Fuso, a 14 ft Alaskan Camper
with roof retracted would look something like this:
I estimate the weight of a 14 foot Alaskan Camper popup to be
about 2300 lbs, no problem for the Fuso FG's cargo carrying capacity
of more than 8,000 lbs.
The Alaskan Camper, like most truck camper designs, holds its clean
water, propane, and waste water in tanks inside the camper shell, rather
than in tanks attached to the truck chassis. Because the camper is
self-contained, it can easily be unbolted and jacked up from the
truck frame. Once the truck is driven out from under the camper, the
camper can be lowered onto a dolly and wheeled away for storage in a
standard garage. Or the camper is left in place on the jack stands as a
base camp.
Price is pretty reasonable. The Fuso FG 4x4 costs about $32,000,
a torque-free flatbed frame for the camper about $4,000, and the
custom popup $30,000, maybe more if you mount a set of solar panels
and extra batteries.
Hmmm, I'm liking this Alaskan Camper & Fuso idea!
Chip Haven
haven
Alaskan Camper interior
Here's what the Alaskan Camper interior looks like
This is obviously a photo of the cab-over model, but the interior length
is about 14 feet. A custom 14 ft non-cabover model would have all the space
below the bed for storage. Or you could design a different layout altogether.
Despite being a popup design, the Alaskan Camper has a set of useful
cabinets mounted at ceiling height. I guess by using a hydraulic system to
raise the roof, Alaskan Camper does not worry too much about the
weight of the roof.
Chip Haven
VikingVince
I've looked at these several times over the last few years...and IMO, what is most attractive about these units is the hard sided pop-up aspect with it's corresponding low profile and low center of gravity. The biggest drawbacks for this $30K camper are the bathroom OPTIONS - an interior Thetford cassette toilet and an outside shower! Bummer...they could easily design at least a wet bathroom/shower...along the lines of the popup tent trailers. Again, just my opinion, but the lack of that feature is a real deterrent to considering this unit as a multi-year expedition vehicle. I know most wives wouldn't be too happy:rolleyes: Chalet RV is supposed to be coming out with a hard-sided popup truck camper later this year. It's not on their website yet but was shown in a magazine.
haven
shower? we don't need no stinking shower!
It's true that the interior water closet is an option on the standard Alaska Camper price sheet. The nice thing about a custom layout is that you can specify pretty much what you want. The $30K price will include cassette toilet and hand-held shower inside.
The Chalet RV hard-side popup is interesting:
I wrote to the Chalet folks in June, and they confirmed the popup will be available this Fall. Its floorplan will be similar to this popular Lance model:
The problem with the Chalet hard-side truck camper is that its body is too low for the cab-over to fit. The Fuso's cab is about 13" taller than a typical pickup truck's cab.
You'd have to
1. mount it backwards (so the cab-over sticks out the back); or
2. mount it to the rear of a longer flatbed, like Doug Hackney is planning; or
3. build a 13" storage compartment under the camper to raise it up high enough so the cab-over section will clear the Fuso's cab.
I'm a little worried about the Chalet RV's construction. Its 1150 lb dry weight is about half that of the Alaskan Camper!
Chip Haven
18seeds
I heard they delayed the release of that hard side pop up.
Alaskans are great campers major problem to me is that you have to instal the walls in the cabover when raising. In a snow storm or rain that makes for a wet bed. This is my new camper that I will test out this weekend
haven
wet bed
The "wet bed" will be a problem for the Chalet RV hardside popup, too. They use the same folding sidewalls in the cab-over that Alaskan Camper uses.
Here are some specifications for the Chalet RV popup, courtesy of OutbacKamper's post at www.expeditioncampers.com
Interior floor length 99”
Interior height 87 ½“
Cabover interior headroom 37”
Exterior width 88½”
Exterior height above truck bed (when folded) 59”
Fresh water tank 15 gal
LPG tank 20 lb
Refrigerator 3 CU ft
Furnace 16k BTU
Exterior roof length 14½ ft
Approximate Dry weight 1158 lb
Aside from the skimpy fresh water tank and small refrigerator, these specs match up well with other popups on the market.
Chip Haven
fisher205
Hi, I'm new to forums, but have an old Alaskan camper on a Dodge Ram Diesel.
I am slowly( and I mean slowly) building it for offroad/ traveling use.
I would like to address some of the problems previously listed in the forum:
Weight - That's for real, the Cummins handles it, but I wouldn't put it on a small gas burner myself. I would also look more at the Alcan if I was buying new.
Bathroom: My experience now is I wouldn't have a bath/blackwater/ shower system. If you are going to be away from a campground more than 3 days, It is hard to carry enough water for two people. I just use a hand pump for the sink to help conserve water and try to reuse the grey water.
Putting the top up in the rain, - If it's raining that hard, don't put the top up. for awhile. Besides it's not that slow. Mine is just a hydraulic jack and can be set in a matter of minutes.
If you are looking for full baths, showers and expedition capability, I would recommend The Earthroamer, or other large units. Mine is somewhere between pickup w/topper, and the large units.
I have sure enjoyed and benefitted from some of the builds here. Thanks, been fun reading too. - Brad
haven
custom Alaskan Camper on Sprinter
The folks at Alaskan Camper recently built a custom 13 foot camper
for a Sprinter chassis. The Sprinter cab/chassis has a flatbed with
side boxes added for the camper to sit on.
Note the access door to a large storage area just behind the Sprinter
cab. The sleeping compartment is above the storage area.
This is the sort of camper I had in mind for the 133" wheelbase
Fuso FG. The FG can handle a 14 or 15 ft camper without too
much rear overhang.
Note that because there is no sleeper area extending over the
Sprinter cab, there are no folding walls to cause the "wet bed"
problem.
The Alaskan Camper staff seem very interested in working with
your ideas for the interior layout.
Chip Haven
fisher205
I have been considering no overhead camper in the future and the Fuso FG seems to be a very good base for it. If you can get sliding windows to access from the cab would also be nice.
RUF, Inc. www.ruf-inc.com are making some nice vehicles based on the Fuso.
My camper is older and did not have very good care, so I do not mind "cutting" on it a bit. The woodwork inside is so nice I kind of hate to cut it up much.
I have thought about pitching the stove/ oven combo, and putting a quick couple inside and out for a Coleman or Brunton Propane stove. In the summer I would rather cook outside and it seems silly to carry two stoves.
I have been putting a lot of time into the camper but will start upgrading the truck. It has been capable as I got it. but will start getting more attention. I've only put a power upgrade and air bags into it at this time. - Brad
Gold Boy
bump
selling my house and hope to be doing the FG custom Alaskan camper thing....
can't think of a better combo for the price....
Gold Boy
spoke with Alaskan camper today. they said a custom Alaskan camper for the fg costs $25000 US, about the same price as there large cab over camper.
also spoke with mitsu fuso, the fg costs $45000 CAN + tax
i am allowing about $5000 CAN for a flat deck.
budget for $85000 CAN, give or take.....
cheers
dhackney
If you are in BC you might want to check out:
Hi-Lite Truck Accessories Ltd
5620 Landmark Way
Surrey, BC V3S 7H1, Canada
(604) 534-3838
They've got some experience building expeditions rigs based on the FG.
I don't know what they'd charge you for the deck, storage boxes, etc.
erod
alaskans are awesome! they actually made one for short bed trucks for a while...saw one on an old toyota here in town...it was for sale too! they are realy big though for small size trucks, maybe why they discontinued making them. still wish i would have bought it. looking forward to more on the build as it comes along...
Gold Boy
yer, there are many advantages with the AC; one of which is they are a known quantity as many have been sold ....
and also a low profile/center of gravity, good quality build.
WonaWarrior
