toyota bolts
Loober
Does anyone know off hand the specs(thread type, pitch, length) of the most common toyota bolts. I want to put a collection togther to bring with me on trips, you can only borrow bolts from other parts of the truck to an extent.
DaveInDenver
Middle Income Semi-Redneck
Common JIS sizes on Toyotas (mostly considered metric fine thread):
16mm x 1.50
14mm x 1.50
12mm x 1.25
10mm x 1.25
8mm x 1.25
6mm x 1.00
Lengths will vary, but I personally carry the bulk of my spare hardware in 8mm, 10mm and 12mm in a few lengths. Mostly 25mm and 40mm and some 60mm lengths. I carry a few specific bolts, a couple of caliper bolts, upper ball joint bolts (I use BJ spacers, so I have 120mm long grade 10.9 socket cap bolts), a couple of extra shackle bolts for my suspension (in my case 14mm and 18mm stock diameters), an extra saddle bolt/nut for the torsion bar mount, extra driveshaft bolts.
Loober
I just ordered these from McMaster: Four different sized bolts of a couple lengths with nuts, lock washers, and flat washers and a compartment case all for $150, pretty good id say. They are not all of the highest grade but I dont think they need to be
1 1
Pack 90854A167 Metric Znc Yellow Pltd Stl Hex Head Cap Screw Class 10.9, M8 Sz, 25mm L, 1.25mm Pitch, Fully Thrd, Packs of 25 (Same as 90854A113)$8.46 $8.46 today
2 1
Pack 91310A541 Class 10.9 Black Fnsh Stl Hex Head Cap Screw M8 Size, 40mm Length, 1.25mm Pitch, Fully Threaded, Packs of 25$9.34 $9.34 today
3 1
Pack 91180A630 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M10 Size, 25 mm L, 1.25 mm Pitch, Fully Threaded, Packs of 25$8.67 $8.67 today
4 1
Pack 91180A640 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M10 Size, 45 mm Length, 1.25 mm Special Pitch, Packs of 25$13.54 $13.54 today
5 1
Pack 91310A342 Class 10.9 Black Fnsh Stl Hex Head Cap Screw M6 Size, 40mm Length, 1mm Pitch, Fully Threaded, Packs of 25$6.34 $6.34 today
6 1
Pack 90591A151 Metric Zinc-Plated Steel Hex Nut Class 8, M6 Screw Size, 1mm Pitch, 10mm W, 5mm H, Packs of 100$2.21 $2.21 today
7 1
Pack 90592A022 Metric Plain Steel Hex Nut Class 8, M8 Size, 1.25mm Pitch, 13mm W, 6.5mm H, Packs of 100 (Same as 90592A555)$4.32 $4.32 today
8 1
Pack 91415A225 Metric Zinc-Plated Steel Fine Thread Hex Nut Class 8, M10 Screw Sz, 1.25mm Pitch, 17mm W, 8mm H, Packs of 50$10.22 $10.22 today
9 1
Pack 90326A120 Metric Class 4 Zinc-Plated Steel Thin Hex Nut M12 Size, 1.25mm Pitch, 19mm Width, 6mm Height, Packs of 50$7.25 $7.25 today
10 1
Pack 91169A200 Metric Black Steel Spring Lock Washer M8 Screw Size, 8.5mm ID, 14.8mm OD, 1.9mm min Thk, Packs of 100$2.75 $2.75 today
11 1
Pack 91169A214 Metric Black Steel Spring Lock Washer M12 Screw Sz, 12.7mm ID, 21.1mm OD, 2.35mm min Thk, Packs of 100$5.89 $5.89 today
12 1
Pack 91166A270 Metric DIN 125 Zinc-Plated Steel Flat Washer M8 Screw Size, 8.4mm ID, 16mm OD, 1.4-1.8mm Thick, Packs of 100$2.73 $2.73 today
13 1
Pack 91166A280 Metric DIN 125 Zinc-Plated Steel Flat Washer M10 Screw Size, 10.5mm ID, 20mm OD, 1.8-2.2mm Thk, Packs of 100$3.98 $3.98 today
14 1
Pack 91166A290 Metric DIN 125 Zinc-Plated Steel Flat Washer M12 Screw Size, 13mm ID, 24mm OD, 2.3-2.7mm Thick, Packs of 100$7.01 $7.01 today
15 1
Pack 91180A724 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M12 Size, 50 mm Length, 1.25 mm Special Pitch, Packs of 10$7.85 $7.85 today
16 1
Pack 91280A550 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M8 Size, 60mm Length, 1.25mm Pitch, Partially Thrd, Packs of 25$7.74 $7.74 today
17 1
Pack 91180A644 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M10 Size, 60 mm Length, 1.25 mm Special Pitch, Packs of 10$6.46 $6.46 today
18 1
Pack 90854A139 Metric Znc Yellow Pltd Stl Hex Head Cap Screw Class 10.9, M6 Size, 25mm L, 1mm Pitch, Fully Thrd, Packs of 50 (Same as 90854A113)$9.44 $9.44 today
19 1
Each 45865T31 Compartmented Plastic Box with Handle 24 Compartments, 18-1/2" L X 13" W X 3" H Overall$26.29 $26.29 today
Merchandise $150.49
Applicable shipping charges and tax will be added.
DaveInDenver
Wow, nice.
Just something else that I thought about. Toyota sells all the hardware and it's not too unreasonable. It's hard to find those bolts with the captive washers in the hardware store and I get them from my dealer.
Also what is nice about OEM hardware is that it's the same drive socket size as original. The stuff I get at the hardware store is usually not. What's the difference? The drive head size. For example the stock 6mm/8mm/10mm bolts use a 10mm, 12mm and 14mm socket. From the hardware store it'll usually be 10mm/13mm/16mm. No biggie, just has always bothered me.
DaveInDenver
What do you mean by not too unreasonable, like how much would 25 bolts run you
I dunno, have to check a receipt when I get home. I've been going to my parts guys for years and get a pretty decent price schedule. But when I built my engine a couple of years ago I replaced just about every single bolt on it (a 22R-E) for around $100 or so. I'd guess there are around 35 or 40 bolts when you add it all up. But retail, just don't know, probably gonna be higher than a hardware store. It's stuff like this that makes getting to know your parts guys a major advantage (you know a few bolts here, a few filters there, all that misc junk adds up to real money in a hurry).
jgrillz94
