23 Zero Litchfield Roof Top Tent with Annex 2 person RTT
sethro80
The 23 Zero TENT IS SOLD SOLD SOLD
But I do have a 1600 Howling Moon Stargazer RTT available for $1600.00 and it is in very good condition.
Here are the images. Local Pick Up in Flagstaff AZ only.
23 Zero LITCHFIELD Roof Top Tent with annex $900.00 Located in Flagstaff AZ, no shipping, local pick up only.
The tent has been used but is in great shape. It sleeps 2 adults comfortably. Comes with the quick zip on annex room. Here is the info:
The 23-ZERO roof top tent gives you the freedom and confidence to tackle the outdoors. Its heritage spans from two of the most outdoor counties in the world, Australia and the USA. Whether its may be a journey into the desert along the coast or that new track you have been wanting to explore. Beautifully finished from a tough ripstop polycotton canvas ensures you will stay comfortable and dry, inside the closed cell mattress makes the nights sleep a dream or you can just look out through the sky window and watch the stars go by. The included annex has a unique removable adjustable floor, from 68” to 82” to allow for larger vehicles or uneven ground.
Features include covered aluminum internal frame pivoting on a stainless steel hinge. The sturdy aluminum base is filled with hi-density polystyrene foam providing extra strength and insulation. It fits most roof racks and comes complete with fitting kit, guy ropes, window stays and instructions.
FEATURES AND SPECIFICATIONS
1 Sky View Window with 2 layers, Outer is the same ripstop polycotton as the tent and an inner of ultra fine insect mesh
2" thick covered closed cell hi-density mattress
260gsm polycotton ripstop canvas
210 Denier fly
210 Denier oxford polyester ripstop annex
A 82" (2100m) sliding alloy square ladder
Internal frame is 5/8" (16mm) diameter tube (covered)
Oversized 1" (25mm) diameter awning hoop
Cast alloy frame lugs with stainless steel hinge
Alloy base
Alloy pivoting yoke provides strength and reduces weight
Adjustable fly helps prevent condensation and ensures constant airflow in all conditions
Heat sealed seams
Side vents improve air-flow
68" (1720mm) to 82" (2100mm) annex height
98" (2.5m) annex length
Removable 550gsm PVC tub style floor for easy cleaning
Large 35" (900mm) Wide x 55" (1400mm) High annex windows with super fine insect mesh throughout
600gsm PVC transit cover with D ring tie downs
Removable pack down bungee cords included
WEIGHT*
138lb including Annex
DIMENSIONS SET UP*
Overall 56" (W) x 121" (L) x 50" (H) does not include fly overhang or window awnings
Sleeping area 56" (W) x 96" (L) 49" (H) inner tent
Projection of tent over ladder 56" (W) x 27" (L)
Awning footprint 98" (L) x 60" (W)
Awning height from 68" to 82"
OmegaMan73
Could you fit 3 people in there if you needed to? It's me, my wife and a 10 year old. Think that's a bit tight?
sethro80
dhuss
