huntsonora
Is that a Tundra? If so, a 265 might be the better option to keep road damage down if you spend time on soft private roads... I had 235's on a 2500 GMC a while back, and while it was rock solid on them, and got great mileage, it would find the bottom if the ground was soft... Sometimes the bottom is not near the surface...It always got through, but the ruts I left were sometimes fairly significant... A lighter vehicle may not be so affected.
Also, if your wheels are wider than about 7", a 235 may be stretched a bit to cover. I put a set of 235/80R17's on a 7.5" wheel, and it was OK but the 17's are typically a bit wider than the 16's, and I was a little worried about the sidewall, which was fairly exposed. (Never had an issue though...)
Any luck with finding a better deal on Hercules tires locally? I'm about to put the TerraTracII's back on the road under the Comanche project. I still maintain they're as good a tire and comparable in performance to the AT3. It's just a matter of price.![]()
Its a 1st gen Tundra DC so its not as heavy as the new ones. I haven't had any luck with finding a Hercules tire yet BUT I can get a hell of a deal on the AT3's right now at Discount. In fact they would be about $150 less for a set than the 265 ATP's
Here is my truck with 265 ST Maxx tires...
265 ST Maxx-54lbs
265 ATP-49lbs
235AT3-42lbs
Not that the weight is the end all be all, it would be nice to get a little power and mileage back though. Hell, the ATP's at 5lbs less would make a little difference
