3.5L IACV Gasket
So I was getting a CEL for IACV so I pulled the throttle body and removed it. The gasket ripped as I separated it, but I can't seem to find a replacement for it anywhere. I checked the local parts shops and no one had it, I can't even find it on ebay. Is this referred to as something else? I looked up variations of "IACV, idle air valve gasket, idle air motor gasket, idle air seal, etc" Below is a photo of the seal that I need.
Awesome, thank you so much! Nothing came up on ebay because they're only advertised for the Diamante 3.5L apparently, nothing for the Montero.
Salonika
Monterror Pilot
Mitsu factory part # is 07729 from exploded view 07700A. Those numbers are from a printout I got at dealer. Just did this two weeks ago. Dealer can get it. I wonder why dealer printouts don't use the MD #'s?
Thank you, I don't have any dealers around me, so I had to go to Oreilly's. I went before I made this post and they didn't even know how to look it up in their system and couldn't help me, even with the exact info on the vehicle, part name, and physical part that I had with me. After KyleT's post, I went back with the number he provided and they found it right away, what do ya know.
KyleT
The parts diagram reference number is not the same as the actual part number you have to cross reference it. I use www.partsbase.org it shows both.
flipstick
