3 Amigos - Can I drive with it?
Big D
Did the brakes and the 3 amigos seem to have come on. Did some research on how to fix it and will eventually get around to it but can I still drive around with it on?
Is the system fully disabled when lights are on?
When stepping on the brakes hard, it feels like there is some slight modulation and it seems like the brakes warm up too much.
Thanks for any info
AKRover
You can drive with the lights on. Since you say you just did the brakes and the lights came on it sounds like something you may have done. Did you mess with the abs sensors at all?
R_Lefebvre
The lights only indicate that the system is inactive. It is OK to drive with the system inactive, though you will not have ABS brakes of course, which may be a problem or not depending on how you drive. Lots of people drive around with the lights on.
However, that is not to say that your entire braking system is ok. If this happened after you did a brake job, only you can guess what might be wrong.
Clemtiger84
