Heating a Wildernest/Flip-pac
rusty_tlc
I'm have 95% completed a prototype of a Portable Propex Heatsource heater.
I have the furnace mounted in a steel box with all the hole cut for the gas, air inlet and outlet, and the combustion side air intake and exhaust.
I should have it fired up tomorrow for testing.
The production model will have a fast disconnect gas line, but right now I'm struggling with gas fittings.
The furnace has a 1/4" female BSPT threaded fitting (found that out at the last minute).
I have a conversion nipple from 1/4" BSPT to 1/4" NPT thread.
Then I want to go straight to a quick disconnect gas fitting. The issue is the quick disconnects have NPTF threads. I'm trying to keep this as short, in length, as possible, and I need to find a 1/4"NPT female to a 3/8 NPTF female.
I think I'm in plumping hell :wings:
I'll start a new thread on it once I get it fired up tomorrow with some temporary fittings.
Brass is pretty easy to mill and thread, couldn't you do a special fitting from 1/4" BSPT to 3/8" NPTF?
DaveInDenver
Middle Income Semi-Redneck
Folks around here have taken out the driver's side window of their WilderNest and fitted a blank panel of either aluminum or plywood. They then cut a hole in that panel to fit various RV heaters. A couple of things come to mind, first a few have burned their camper and trucks down. There is a whole lot of non-fireproof nylon (you have to be very careful of the driver's side curtain and tent divider that hang down) and usually gasoline fumes in the back of your truck. Second, it's generally to minimal effectiveness due to the aforementioned expansive nylon. Personally in the winter I put a layer of closed cell foam and a wool blanket under the mattress and pull out the heavier sleeping bags and we're good down to zero-ish. The curtains are very important, keep 'em closed and the sleeping area is noticeably warmer. Getting up in the morning, now that is a real wake-up, though! Keep it simple, invest in good down booties and a down sweater.
paulj
... Personally in the winter I put a layer of closed cell foam and a wool blanket under the mattress and pull out the heavier sleeping bags and we're good down to zero-ish.....
Heat loss through the open cell foam mattress that comes stock with the Wildernest is an important consideration, though the foam core (or what ever it is) inside the fiberglass lid provides some insulation of its own. That combo of close cell foam and a wool (or fleece) blanket should make a big difference.
Rando
That is the route I took with my Zodi heater. I made a plywood blank that would fit in the sliding (side) window opening and would then close the window against the blank to seal it off. I have two holes cut in the blank for the Zodi inlet and outlet ducts. I guess I could take the same route with a propex, but ideally it would be permanently mounted in one of my cabinets, so all I would have to do is flick on the thermostat and feel the warmth!
I am also not concerned about heating the wildernest while sleeping - I have a -20 F sleeping bag and a ridgerest on top of the open cell foam mattress as well as a 12v electric blanket. What I want the heater for is having somewhere to warm up and cook after a day of skiing, and a warm place to wake up and get dressed in the morning. I replaced the normal curtain between the bunk and rest of the topper with an insulated one so that I can essentially just heat the topper side of the 'nest.
Unfortunately it has been way to warm in the evenings here (40F) to do a meaningful test with the electric space heater. One of these days winter will return and I can try it out.
ExpoMike
So Martyn, what's the verdict?
After our recent Death Valley trip, where Saturday night it was 27* inside our Kamparoo, a heater has become a very wanted item. Since 90% of our camping will be done in late fall, winter and early spring, temps tend to be low overnight. The HeatSource seems like an ideal (if exspensive) unit but I would like some real world accounts before dropping that much $$$.
Martyn
Mike
Sorry for the delay in updating you. As with all prototyping I hit a snag. I needed a two stage regulator to run the unit and there are none in the town I live in.
A trip to Reno to pick one up is out of the question as we are in the middle of a serious snow storm right now.
I ordered parts online and should have them in a couple of days.
Looking at the heater, the specs, and the fact it's marine grade I don't think heat is going to be an issue with this unit.
I'll post as soon as I have something up and running.
Rando
A quick update on the heating dillema.
I never got a chance to run an electric heater in the nest, but I did do a quick experiment with a Mr Heater. With an outside temperature at ~20F and a slight breeze blowing (at an altitude of ~8000') the Mr Heater big buddy raised the Wildernest temperature at about 1F / 10 min on low. I didn't leave it long enough to reach steady state on low. On Medium the rate about doubled to 1F per 5 mins, and on high it approximately doubled again to 1F every 2 minutes. On Medium it reached an approximately steady state temperature of ~45 F. On high it got reached 65 F (after about 20 mins) and we turned it down.
For reference the Big buddy is ~1200 W on low, 2600 W on medium and 5000 W on high.
I need to repeat this test in a more scientific fashion (and hopefully will do so this weekend), but for the conditions that I would be buying a heater for (similar to above), the regular Buddy (2600 W) would be OK and can produce about a 25F temperature rise, but the bigger buddy is fine, with at least a 45F temperature rise. More importantly for my long term plans, the smaller Propex Heat source being talked about here (1900 W) is not going to be able to comfortably heat a wildernest or fllip-pac in below freezing temperatures. The larger Propex ( 2800W) would be marginal, and certainly not worth the $1000+ it would likely cost.
This agrees pretty well with what my VW westy friends have found. The smaller Propex will heat a westy down to about 20F with the top down but with the top up (similar to a Wildernest or Flip-pac) they don't really cut it.
Martyn
When you do your more scientific study, here are a few things to take into account.
The Propex heater can be used in a sealed environment, as the air for combustion and the exhaust from combustion is taken from the exterior. The Mr. Heater heats combusted air and requires 18 sq inches open to the exterior for ventilation.
The Propex heater blows hot air at 60 and 85 cubic feet per minute, with the air coming out of the vent around 125°F, so it's very much like the forced air system in a home.
You also have the ability to re circulate air from the living area and re heat it through the firebox in the furnace.
As the combusted air in the Propex heater is completely separate from the heated air it is free from the condensation associated with direct propane heat.
The biggest issue for cold weather camping is to reduce the amount of cold air coming into the tent or vehicle, and to reflect the heat that is in the living space back into the living space and not have it radiate out.
There are some very effective ways of achieving this, Autohome uses silver reflective winter hoods on their tent, which work very well. There is soft Tyvek http://www.materialconcepts.com/products/tyvek/ product that works to reduce airflow. Other materials like reflective bubble wrap work as insulation layers and reflective layers, or TempShield work as insulation and radiant barriers.
Having lived in snow country for 23 years I know that you can easily heat a house that’s sealed and well insulated. The quality of the heat is much better as there are no cold drafts, you use less energy, and your more efficient. I don’t believe the answer is to throw more heat at the problem.
Rando
I am fully aware that the Propex is a much more elegant system with a sealed and separate combustion and warm air path. I spent several nights in a VW Westfalia camper with a propex and it is an excellent solution for that application. The main reason I wanted to do these tests (I had originally planned to do it with a 1500W electric space heater) was to get an idea of the suitability of a Propex for my application, which is camping in the CO mountains in winter. A Mr Heater is a definitely a poor substitute to a propex for the reasons you listed (mostly moisture), but for me it was worth testing the concept of heating my Wildernest with a $69 Mr Heater rather than with a $900 Propex heatsource. The (minimal) testing I have done so far seem to point to the propex not having sufficient heat output to give me the temperature rise I desire under the conditions I use it. A Propex might be a good solution for people in a warmer and less windy environment or for those willing to make an insulating liner for their tents. Hopefully someone will try this and let us know!
I guess the point I am trying to get across is that I am in no way disparaging the propex, but I am presenting the data points that I have to help others. This weekend I will hopefully have the opportunity to get some better data, and can share that as well.
Smudge12
