Thread: Saginaw p/s on 2F - vacuum issues
  1. #1
    Join Date
    Aug 2009
    Location
    Mesa, AZ
    Posts
    94
    Default Saginaw p/s on 2F - vacuum issues
    Hi. I have an '85 FJ60 with stock 2F engine. I just had the stock p/s pump replaced with a Saginaw pump. I had the smog pump removed, as I haven't had a catalytic converter for years. I immediately noticed a drop in power, the choke stopped working for the most part, and it seems like it doesn't even want to idle, though it will. Because these issues started as soon as I did the p/s swap and smog pump removal, I'm assuming they have something to do with smog vacuum lines. Does anyone know what I need to do? I did some research on Ih8mud and I am not interested in the entire desmogging process. I just want to fix these problems and get back on the road. Thanks in advance.
  2. #2
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    5,496
    Do you have the 2F emission manual?..(If not...search mud)..If i was you and didn't have the smog police.....get her desmogged....your almost there.
    Get a manual...... start back tracking all your lines to make sure all is connected right....
    Nic
    Sierra Expeditions
    www.sierraexpeditions.com
    1-866-507-4254
    2003 LX470
    2012 Honda 450X
  3. #3
    Not sure exactly what you did, but with de-smogs, it's best to go 100% all the way or not do it at all. Your symptoms sound like a vacuum leak.
    Maybe it's as easy as a dislodged vacuum line so look very carefully in the area you were working.
    Also with a full desmog, there is some carb work to do and optimally get your distributor advance recurved.
    KI6MIE
    Sacramento CA
    1997 FZJ80 Desert traveler
    1989 FJ62-OME, 33s, OME suspension, H55f
    1984 FJ60-SOA, H41, toybox, locked, 37s, Rubicon edition
    1971 FJ40-SOA, FJ60 axles, 85 2F, it abides
  4. #4
    cruiseroutfit's Avatar
    cruiseroutfit is offline Sponsoring Vendor Supporting Sponsor: Cruiser Outfitters
    Join Date
    Dec 2005
    Location
    Sandy, UT
    Posts
    8,398
    Quote Originally Posted by AndrewP View Post
    Not sure exactly what you did, but with de-smogs, it's best to go 100% all the way or not do it at all...
    x2, de-smog's do not respond well to half way.
    Check out the JimC desmog diagram available over on IH8Mud
    Kurt Williams
    Cruiser Outfitters
    Your original outfitter for OME - ARB - AA - Safari - Helton - Engel - Since 1992
    Join us on Facebook
    ExpeditionUtah - A lifelong project of exploring Utah
    kurt@cruiseroutfitters.com
  5. #5
    Join Date
    Aug 2009
    Location
    Mesa, AZ
    Posts
    94
    Thanks guys. The problem (with me) is that I'm not mechanically inclined at all. I thought I was making things easier by eliminating the leaky p/s problem. Nobody warned me about the smog issues. I've been looking at the mud threads on desmogging and frankly, that's WAY out of my league. I wouldn't even know where to start and would definitely mess things up big time if I tried. I was hoping there would be some quick fix but it's looking unlikely. Thanks though.
  6. #6
    Join Date
    Mar 2007
    Location
    The Nanny State
    Posts
    5,772
    I'm betting there's a Mud'er near your neck of the woods qualified to supervise the de-smog procedure. Post over there asking for help and you're likely to get more than you can deal with. There may even be someone here able to help.
    semi self-banned
  7. #7
    Join Date
    May 2008
    Location
    Tucson, AZ
    Posts
    554
    Petunia1995 FZJ80
    Suzy 2001 Subaru Forester
    2014 Specialized Crave
  8. #8
    Join Date
    Aug 2009
    Location
    Mesa, AZ
    Posts
    94
    Thank you guys. I appreciate it. Will
  9. #9
    Join Date
    Nov 2008
    Location
    Wyoming
    Posts
    1,201
    The desmog, looks complicated and it is, but if you just take your time, follow the threads on IH8MUD (check out "My Desmog Thread" by some guy named fowldarr) . It's very doable. You will get it done, and it still won't be right, and then you'll figure it out.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
