110user
Hi Steve,
It seems the fan change is proving itself out; maybe a little longer to test ?
Will wait to see if any opinions change
We are planning baja in HOT august... that will be the test!
Hi Steve,
Hello, a question on Post 86 and the internal shot of the back of the ambu.....
The center bulkhead between driving position and rear area, how big a headache was it to create the opening?
From a few pokes around, it seems the bulkhead is around 2" thick and packed with glass insulation, was it a neat and easy job to remove it all and what way did you attack the job? Are the vertical sections either side of the opening and the horizontal piece on top, part of the original structure or did you install them yourself?
I like the idea of an opening between drivers compartment and rear area, but then I like the idea of keeping it contained too. As long as the structure isnt modified too much (i.e, pulling a bit of fibreboard and some wool out), I wouldnt be worried about affecting the rollover protection........
Alec.
... if you need a picture let me know.
