GREENI
Hi guys, I'm hoping that reaching out across the pond may solve an issue I've got.
The 90:
Originally a 4 cyl petrol which had a 3.5 efi flapper engine swap in.
Now I've put in a new, turn key, 4.6 P38 fronted Gems engine, I had lots of trouble getting it running, but it turned out to be an issue with the ECU, partially locked up, but now solved and starts just fine.
Now the issue I have is it will start, but when the key is turned off it doesn't switch off.
I have to pull a relay out to get it to stop, not ideal.
So briefly that's it, I'll be happy to answer more tech questions, but I'm hoping that it may be something that rings familiar with somebody, please!
A pic or two...
The 90:
A pic or two...
