salve7
I have a series 2a that is cutting out at 3/4 of a tank like it it is running out of fuel. I have replaced all filters and have checked the tank for any crazy slime and have found none. The "pickup" tube is free and clear of any problems which leads me to believe that it is the fuel pump. As I am bleeding the fuel system, the manual pumping lever moves freely without much resistance, maybe some pump feel for a 1/4 of the stroke unless I try cranking the engine again which sometimes gives the pump a better feel. Is this normal? I was told that sometimes the diaphragm can malfunction as the engine gets hot but it seems the issue really doesn't crop up until 3/4 of a tank. The previous owner was stumped as well but his solution was to just keep it filled. I am moving in a couple of weeks so I would like to get this resolved as quick as possible so I can use it to move my crap. Any help is appreciated. If it helps I have found that the battery is usually low as well when this happens, just by weird circumstance, but I have no reason to believe that this has anything to do with it other than pissing me off as I try to crank the engine after bleeding.
Thanks,
Jay
Thanks,
Jay
