4 x 285/70 R 19.5 Michelin truck tires
heimbig
OnTheRoadAtLast
4 tires (4000 miles of use) + 2 super single wheels, no usable front wheels. 285/70R19.5 Wheels are 19.5 by 7.5" wide. Fit: Ford super duty '05-up F-450/550, F-53, 10 lug x 225mm PCD, 170.1mm Bore. Also fit 2008-up Dodge 4500/5500 and Sterling Bullet and probably others.
Maximum load per tire 6395 lbs (vs stock 3970)
2 Rickson steel rear wheels as super single have a 7' wide track (or can be reversed and be 7' 5" wide)
2 Michelin XDE2+ tires M+S Plus free wheels
2 Michelin XZE2+ tires. no wheels. With the appropriate wheel this tire will fit in the Ford wheel well without modification.
I paid $4500 for the 4 wheels and 4 tires. The front Rickson wheels are no good but the rear wheels are fine.
$800 For all 4.
Compared to stock:
With Rickson rear wheel:
Rogers87
Do you still have these for sale? I'd be interested in buying them. I'm curious what happened to the fronts?
