43Q camping fridge
unseenone
EdgeStar 43 Quart 12V DC Portable Fridge/Freezer - Grey new / retail $610.00 Amazon $386 - 452
Keep your foods and drinks chilled or frozen while traveling with the EdgeStar 43 Quart 12V DC Portable Fridge/Freezer (FP430). This powerful unit puts the strength and insulation of a home freezer into a compact and rugged appliance. For ultimate portability, the EdgeStar 43 quart portable compact refrigerator freezer runs off standard household voltage, or easily connects to the cigarette lighter outlet in your car. Forget about thermoelectric portable coolers - this portable refrigerator freezer features a full range digital thermostat that is adjustable from -8 to 50 degrees F and will hold a stable temperature under most conditions. Plus, the insulated metal walls will keep your food cold for hours, even without electricity.
If you're in a hurry to freeze something, press the Fast Freeze button to rapidly cool the unit to -8 degrees F and maintain this freezing temperature. With side-grip comfort handles for easy transport, two (2) removable wire baskets for efficient storage, and a drain for liquids, this portable refrigerator freezer is great for boaters, campers, hunters, medical transportation/storage, recreational vehicles, cabins and all your outdoor applications. The FP430 may be powered via AC (0.75A) or DC (5.4A @ 12V DC / 2.7A @ 24 DC) power and comes with cables for both applications. You may plug the unit into both power sources at once and the unit will switch between the two automatically with the AC power being the dominant source.
Full Range Thermostat:
The portable fridge freezer's thermostat can both freeze and refrigerate your food and perishable goods
Fast Freeze Function:
A quick push of the Fast Freeze button cools the compartment down to -8 F in a matter of minutes
AC and DC Adapter Included:
Plug the fridge freezer into the cigarette lighter of your car or any plug in your house without having to buy extra accessories
Insulated Metal Walls:
With the insulated walls, you can keep your goods cold long after the power's gone
Specifications:
Model: FP430
Brand: EdgeStar
Operates as a portable freezer or refrigerator
Flash Freeze function
Rounded edges make it safe around the family
Capacity: 43 qt. (equivalent to 60 12oz. cans)
Easy-to-use control panel
Temperatures: -8 to 50 degrees F
Voltage power (AC or DC)
6 foot 12/24 volt detachable power cord
8 foot 115 volt detachable power cord
ETL approval
Warranty: 1 year parts; 90 days labor
Durable and rugged design
Floor drain
Insulated lid
Side-grip comfort handles
Compressor-based cooling method freezes fast
Input voltage: 115 V/60 Hz
Power: 65 W/0.75 A
Weight: 45 lbs
Internal Dimensions: 11" H x 11 7/16" W x 14 15/16" D (large basket) / 7" H x 11 7/16" W x 7 1/16" D (small basket)
External Dimensions: 20 13/16" H x 24 11/16" W x 17 11/16" D
