4th gen 4runner dual battery setup: Difficulty level?
Martinjmpr
Wiffleball Batter
So as I'm exploring which portable 12v jump pack to get, I'm also thinking that, running a fridge on long trips, I like the peace of mind that comes with having a dual battery setup.
However, I don't know what the difficulty level is of putting one together. Ideally, I'd like a system that would allow me to charge both batteries, keeping them constantly charged, but to "isolate" one so that if one goes dead I can still start the truck using the other one.
One nice thing about 4th gen 4runners - at least the V6 models - there's no shortage of space under the hood.
So my question is, what kind of dual battery setups do people have and how difficult/expensive were they to do? Is there some kind of "kit" that contains all the parts I need or would I have to put together my own from an assortment of parts? Are there any special considerations to protect all the sensitive electronics/ECUs in the 4runner (I think it has a lot of them!)
My guess is that a dual battery setup is "overkill" for what I need (if anything, maybe just "investing" in something like an Optima red-top battery would be the way to go.) I don't go on multi-month expeditions far from civilization, I don't run a winch or a lot of off-road lights, and I don't operate a lot of radios or other aux equipment. In all likelihood a decent jump pack stuffed in the cargo compartment should give me all the margin of safety I need while traveling, but I thought it might be worth it to at least explore the dual-battery option, even if just to rule it out on grounds of practicality/cost/difficulty.
Thanks in advance!
Martinjmpr
Wiffleball Batter
ARK Pak?
OK, doing more research - starting to think something like an ARK-PAK might be the solution I need. Expensive, yes, but I like the idea that you put your own battery in it. Looks like it could work as a "poor man's dual battery setup" that could be removed from the truck when not needed (and used for the next truck, and the one after that, etc.)
4Running
I have a National Luna dual battery set up on my '07 V6. The controller is mounded in my arm rest storage compartment. I'm running Odyssey batteries (Main: PC1700MJT-A, Aux: 34-78-PC1500DT-A). The auxiliary battery is mounted on a Dirty Parts FJ Cruiser Dual Battery Tray. I used marine grade cables to link the batteries. All my accessories are connected to the auxiliary battery through a Blue Sea Systems fuse block on a Stinger Circuit Breaker, with the exception of my winch. I'm very pleased with the set up, but will warn you that it was not inexpensive.
djsixbillion
I bought a National Luna Portable Power Pack (similar to the Ark Pak) 4 or 5 years ago and have been very happy with it. Installation is easy, just heavy gauge wire from the main battery to the NL unit and you're good to go. Also enjoy the mounting flexibility, and I do use it in both my trucks. Moving between the two is as easy as undoing a ratchet strap and disconnecting an Anderson plug.
bicyclist
Read this thread and it will give you the info to build your own dual battery setup (though not quite for $50):
http://www.expeditionportal.com/for...ke-a-cheap-isolated-dual-battery-setup-for-50
I used it to rig a house battery in the bed of my Tacoma. The battery is housed in a battery box into which I've installed a pair of Blue Sea outlets, a voltmeter operated by a momentary switch, and a pigtail to use with an AC charger. The main feed from the truck is connected using Anderson power poles so that the box can be easily removed. Everything is fused.
Houie
