liquidglano
Only 90,000 miles, for real
Super safe, reliable, manipulatable, adaptable, powerful 4x4 Ford 350 Turbo Diesel with tons of critical recent work. Has been driven to ensure major work was successful. Original Hortons Manuals included with many replacement bulbs and fuses stocked. Currently driving daily to enjoy the winter season where this vehicle really shines. Performed tranny flush every two years for life. A test drive will tell you all you need to know. We bought this from the Parkdale fire department where the chief was also a mechanic and have enjoyed for 7 years. It's paid off and we've moved on to new projects, so time to find the next owner.
Some nice improvements and amenities we’ve added or appreciated are....
Hand built, heavy duty, Power Cord for power, charging and engine heater.
Rear solid steel bumper with trailer hitch from Schloscher's Welding, and trailer electrical hook up.
Front grill protector (hit a deer once, barely noticed)
Floor mounts for tying down motor bikes
Premium bluetooth stereo with nice 10” woofer between the front seats
Inverter, Air Compressor with hose and attachments, Air bag suspension that raises or lowers back end, 4x4 Low/High transmission, battery charger, block heater (new OEM), rear heater for back box, Charged and checked AC, ABS, fog lights, scene lights, modular wood stove venting system (quick set up), basic cooking station, tons of storage, electric step, programmable Horton Ambulance lighting options (amazing versatility), can buckle up 6 passengers, and more.
Recent work below, with receipts, shows that most of the accessory components to the engine have been replaced and serviced, along with most major gaskets and seals. This vehicle is ready and set for a very long life.
This year:
2 new 65 XT - Xtreme Power (850 cold crank amps each) batteries from Les Schwab
Transmission oil flush
New alternator
New water pump
New Oil Cooler
New Turbo and Pedestal (Remanufactured by Pacific Injection w/ one year warranty)
New uppipe
New Cam sensor
New valve cover gasket
New Head Gasket with upgraded ARP head studs
Both heads machined and replaned w/ 1 yr warranty
New Sway Bar link
All hoses and belts Replaced/inspected
New block heater
New battery disconnect Switch
Recent Work
New Injectors & injector cups (9000 miles)
New glow plugs (9000 miles)
Right Sway Bar mount (9000 miles)
Rear, solid steel bumper with trailer light harness port (from Schlosser Machine Inc, Hood River)
Front brakes, pads & rotors replaced (20,000 miles ago)
21,000 miles on six Goodyear Wrangler Duratrac tires (w/, full size new spare)
Call or text Mike, Nine Seven One 6 Seven 8 Nine Seven FIVE O
This year:
New alternator
New water pump
New Oil Cooler
New uppipe
New Cam sensor
New Sway Bar link
New block heater
Recent Work
