4WD Toyota Hiace Van
Di0n
Two years ago I set out on a 6 month roadtrip of my birthplace, New Zealand. This meant at the age of 20 I had to build my first expedition camper. As it was going to be my home full time for 6 months, I needed something that had a comfortable bed and enough room that I could stay inside if the weather was bad, but not so big that it bankrupted me at the fuel pump. I looked at a 1st & a 2nd Gen Toyota Surf (4runner), a Mitsubishi L300 and an L400 before I stumbled across 1992 Toyota Hiace 4x4. It was local and cheap with only 170000kms. $4000 and two weeks later it was mine.
The van was a 2.8 Diesel Manual with selectable 4x4 Hi/Lo ratio. It was also a fairly highly specd model with red velvet interior, separate front/rear A/C & heater, factory curtains and plastic or vinyl trims over all interior steel unlike the stripped out delivery vans.
As for modifications, I fitted 31x10.5R15 tyres and Toyota Surf rims and wound the front torsion bars up two inches. Then my father and I fitted a double bed in the back, along with a gas cooker, 240v inverter & dual batteries.
Although it was an absolute slug in the hills it was unbelievable in every other way. It went anywhere I pointed it, up banks, through rivers, down beaches etc.
ab1985
I do. Check out Ruined Adventures build thread - it's a great example of a well appointed 4Runner sleeping two.
NorthernWoodsman
Adventurer/tinkerer
Great van! I love Hi-Ace's and really wish we could have them here in the states. Looks like a really fun trip and thanks for sharing.
Di0n
Thanks for looking everyone, I put up some more scenery shots of the trip soon.
I'm planning to buy another camper this Christmas, just trying to decide what. Tossing up between another Hiace, a 1st Gen 4Runner (Hilux Surf in NZ), or one of these:
Which should be fairly easy to convert to 4WD using Dyna truck or landcruiser parts.
Mrknowitall
A week or two ago I was on a thread about the litle CC 4x4 Dynas they build in Portugal. I couldn't quite decide what they based the 4wd system on. Looked like maybe 100 series, but could have been Hilux, too. Do you know?
Stone_Blue
I'm certainly no expert, but IIRC, the Hiace's have generally shared the drivetrains from the Hilux/Pickups, and the Dyna's are a little more heavy duty, and have generally shared the drivetrains from the Landcruisers....
I gotta say, all you non-North Americans get ALL the kewl Toyotas!... :(
BigOly
I don't know if I missed all the pics but do you have any interior shots? For some reason I am really diggin the look and functionality of this van! :)
nieldavis
Steering geometry
Hi DiOn
Apologies for resurrecting such an old thread - I don't know if you're still posting on this forum...
I was wondering if you had any problems with camber/castor/toe, clearance on full lock, or rubbing at front/back etc with the Toyota Surf rims and the tyres that you put on?
I have recently bought what sounds like an identical Hiace to yours, and I'm desperate to get rid of the horrible factory steelies on it, but don't want to run into a world of pain with the new wheels that means I have to take a lump hammer to the wheel arches and chop the axle!
No one in the UK seems to sell new wheels with a 6 x 139.7 PCD and a centre bore of 108 mm, so I'm looking at rims from other Toyota's, just like you did.
There's a guy here in the UK that sells a kit for extended shackles for raising the rear leaf springs, and I can wind up the torsion bars at the front, so raising the van's not a problem.
I'd be very grateful for your advice buddy
Niel
