4x Staun Beadlocks for 15"x7-9" wheels
mmccurdy
*** UPDATE: SOLD ***
I have a set of four Staun beadlocks for 15" wheels, brand new never installed. They fit rim widths from 7-9". This is an internal beadlock which seals both the inner and outer bead, and also provides a run flat type capability. Here's a link to a description on Quadratec:
http://www.quadratec.com/products/92603_000.htm
The best price I've seen advertised is around $150 per wheel, so I'm asking $500 for the set of four since they're brand new.
I'm in Santa Clara, CA but also willing to ship. They're not too heavy so shipping would probably be reasonable.
Stumpalump
I use those in the same size. I don't think any modification has done as much for off roading as Stuan internal beadlocks. I can run single digit air pressure and still have enough sidewall suport to keep the tire from squirming. If I hit a rock the internal tube that's at high pressure takes the hit so the rim stays protected. So at 6psi I have a buttery soft ride with the stability of 15psi and the bump absorbtion of 30. Should I mention the traction at 6 or run flat capability? I don't think you should run them flat on the freeway but to get you to the top of a long climb or onto safe flat ground is nice. Good luck with the sale and good choice for the person that gets them.
Clemtiger84
