$90,000
TRUCK IS BEING SOLD AS IS.
TRUCK
FOR THE PAST FEW YEARS I HAVE HAD THIS TRUCK CONSTRUCTED FOR MY FAMILY BUT REALIZE I SIMPLY DO NOT HAVE THE TIME AND SHE’S TO GOOD TO LEAVE SITTING AROUND FOR THE NEXT 10-15 YEARS TILL I DO.
2001 MITSUBISHI CANTER FG637 4X4 HIGH/LOW RANGE
135K KLM
GVM 5500 GCM 7500
SEATS 7, 4 ACROSS THE BACK AND 3 UP FRONT
MANUAL
NEW REAR DIFF (DIFFCO STILL UNDER WARRANTY) /GEARBOX (DIFFCO STILL UNDER WARRANTY) / SELECTORS (DIFFCO STILL UNDER WARRANTY) /CLUTCH
VINYL INTERIOR, 2 DVD PLAYERS MOUNTED IN HEAD RESTS
CUSTOM BASH PLATE/ BULL BAR
17000 POUND DUAL MOTOR SHERPA WINCH MOUNTED UP FRONT, WIRELESS REMOTE
17000 POUND SHERPA WINCH MOUNTED AT REAR, WIRELESS REMOTE
CUSTOM ALUMINIUM TRAY AND BOX CONTAINING A SLIDE OUT DRAW ONE SIDE AND WAECO 95 LITRE FRIDGE FREEZER ON OPPOSITE SIDE (USED TWICE) ON TILTING SLIDE OUT DRAW
NEW MICHELIN XZL 255/100 R16 TYRES (1500KM ON THEM MAYBE)
DUAL BATTERY FOR TRUCK AND A 3RD HOUSE (NOT INCLUDING CAMPER BATTERIES)
DUAL 200PSI CONTINUOUS CYCLE COMPRESSORS WITH A 18 LITRE TANK WITH A COIL HOSE TO REACH EACH WHEEL.
REAR SPRINGS BY MOORABBIN SPRINGS
CAMPER
THE CAMPER HAS A REMOTE CONTROL THAT LIFTS THE CAMPER OFF THE BACK OF THE TRUCK AND LOWERS IT TO MAKE IT EASY TO GET IN, THEN FLICKING A SWITCH ON THE 4 SIDES RAISES THE ROOF WITH THE SAME REMOTE.
6 BERTHS WITH A DOUBLE CUSTOM-MADE INNER SPRING MATTRESS WHICH LIFTS UP TO ACCESS STORAGE UNDERNEATH. 2 DOUBLE BUNKS, FOAM MATTRESSES, 1 SLIDES OUT TO GIVE MORE ROOM INSIDE CAMPER, EACH BED HAS ITS OWN LIGHTING, BETWEEN THE BUNKS IS A CASSETTE TOILET THAT EMPTIES FROM THE REAR OF THE CAMPER.
FROM THE ROOF IS A SPLIT SYSTEM AIRCON/HEATING AND A DIESEL HEATER MOUNTED IN THE SUB FLOOR (VENTED OUTSIDE)
TV BRACKET INSIDE AND OUTSIDE WITH A WIND-UP ANTENNA.
2/ 150W SOLAR PANELS ON ROOF WHICH CHARGES THE BATTERY BANK IN SUB FLOOR.
OUT THE SIDE HAS A ZIP ON SHOWER TENT WITH GAS INSTANTANEOUS HOT AND COLD SHOWER.
THE FRONT HAS A COOK TOP AND SINK WITH A WATER PUMP, 2/80 LITRE FRESH WATER TANKS IN SUB FLOOR.
CANVAS POP TOP WITH FLYSCREEN’S AND CLEARS ALL THE WAY AROUND.
WIND OUT DOMETIC BOX AWNING.
ANOTHER 95 LITRE DOMETIC FRIDGE FREEZER.
WHOLE THIS IS SET UP TO PLUG INTO MAINS/GENERATOR OR SOLAR/BATTERY
TRUCK
135K KLM
GVM 5500 GCM 7500
MANUAL
CAMPER
