4x4 Motorhome in Utah $2500.oo
Ford Prefect
Not affiliated,
It is an older Ford base, but it looks fairly nice considering.
It is only $2500.oo
Anyhow, thought I would point it out.
http://www.ksl.com/index.php?nid=218&ad=11323288&cat=143&lpid=5&search=
Cheers
Still available
2WD
65K
4.9 6cyl
low gears
owned for 1 years
Per owner - needs tires and some TLC but overall in very good shape
previous owner stored it in a warehouse
Sounds like a deal for the right person not in a hurry
My bad on the 4x4, sorry, still might be a nice vehicle for someone if you like it.
Cheers
Christian P.
Staff member
I like it a lot! Can someone look at it? I wonder if it has a 6 cyl?
I don't think it 4x4 but it should be easy to retrofit
RR1
Be able to throw a TTB under there no problem.
Regcabguy
Oil eater.
Clean macheen. Throw a limited slip on the back and a little suspension upgrade and you're ready to go many places with the granny low. Hopefully,it's not a six as it would be a dog with all that weight especially being carburated.
864x4rv
I also called Brandon on his two listed numbers and left a message. I would be interested in buying it and taking the camper and installing it on my 1996 F250 diesel 4x4 with the SAS. Looks nice in the pictures.
Terrainist
When I tried to call earlier, I tried his landline and it was busy. Waited thirty seconds and called again, it rang no answer. This happened twice, busy then rang no answer. No pick up on the cell twice. Makes me think out of state calls are getting screened ... so you might say in your message that you want to buy it. Rather than you are interested. Even if you don't buy it, you have a better chance of getting his attention.
LandCruiserPhil
Still available
2WD
65K
4.9 6cyl
low gears
owned for 1 years
