4x4 trailer with Ruggedized Tepui Fremont, Ca
CaliXTerra
Take it all for 3K.
Dimensions added
Pics added
4x4 trailer with Tepui Autana 4 ruggedized.
Ready to tow!
Will separate.
Will sell yaks too.
11.5' end to end
4' wide frame base
6'2" outter fender to outter fender
Heavy duty 4x4 trailer with:
Good condition full-size "trailer" tires
6x6.5 steel wheels
Barely used Tepui Autana Ruggedized in OD Green
Heavy duty material and zippers
Aluminum diamond plate floor
Memory foam mattress
Condensation mat
Rain fly
Annex room
Removable aluminum boiler-plate storage compartments
3500lb torsion independent suspension
high clearance axle
10k lb rated pintle hitch
Trailer brakes
12v Auto-brake saftey disconnect
Room to build off of.
Needs uprights bolted on or welded onto the trailer base.
Depends on if you want everything removable or not.
Has perm plates.
510 359 3118
CaliXTerra
As best i can tell, its a trailer frame from a shipper, welder, or power distribution.
It has some paint discoloration that looks just like coolant. I assume the machine it was intended for finally took a dump, before i purchased it from the farmer.
Its heavy wall C channel (not u channel or stamped) and its no doubt best suited for construction site use, etc
CaliXTerra
Still adding pics
CaliXTerra
  • STKUSA
  • 35 7/8in L x 17in H x 17 7/8in
  • Aluminum tread plate in a bright finish
  • Features a weather resistant sealed door and a heavy duty hinge
  • Lock with two keys
Goldenbora
