5200 lb axle vs 3500lb axle? and axle q's
java
Looks like im gonna go with abc trailer and adapters. Its 250 for the axles w/ brakes and springs from them. And adapters are about 100. 6 robbles wanted 550 and I would still need adapters to make it hub centric.
upcountry
Also check southwest wheel. You can get a 3500# axle with 10" drum electric brake with 6 lug 5.5. Also you can run lug centric wheels on your 4 runner just use acorn nuts not shank nuts. Your stock spare is lug centric and the stock shank nuts actually have an acorn beveled tip on them. Ask me how I know...... the only reason you would need adapters is if you wanted to run a hub centric wheel on your trailer axle, I.e. match the stock wheels. Its personal preference at that point but since the spare will work on either I plan to save the 100$ and plan to use 2 stock black steel wheels that way the spare works on either the trailer or truck and the stock lug nuts work for either.
java
the 4runners have a matching spare. i want to run the matching wheels, but i could do two taco steelies if i had too
upcountry
It came with a matching wheel? I knew I should have gone with th 4runner. Darn cheap rust prone spare steelies.
iStan814
