Thread: Eezi-Awn 2.5M Awning mounts on an 80
  1. #1
    Join Date
    Mar 2009
    Location
    MPLS, MN
    Posts
    318
    Default Eezi-Awn 2.5M Awning mounts on an 80
    I did some searching around and found out that not many people had posted how they mounted their awnings, so here's how I did mine attaching a series 2000 2.5M to Yakima bars.
    This is the backside of the aluminum case. As you can see it has an aluminum welt as part of the case extrustion, this is how the Eezi-Awn factory mounts attach, plus they use a bolt thru the bottom, like I did. I figured if the engineers in South Africa are going to do this, I should rely on the strength of this extrustion too! So I did. I didn't have a lot of time and I have lots of scrap, so:
    1 I grabbed some 1.5"x2" tube and some 2"x2", cut it at opposite corners so I had a z shape.
    2 welded it together so that the bottom edge of the z went under the case and the top edge of the z sat flush with the case top.
    3 drilled a hole just larger than the welt into a piece of 3/16" bar stock
    4 cut the bar stock into a triangle thats made by the verticle of my z bracket and the top corner of the awning case where the welt is.
    5 cut a notch into my triangle piece so it can slide onto the welt,
    6 then tack it on
    7 drilled holes for the stainless U-bolt on the top z
    8 drilled a hole on the bottom of the z for the bolt that will go into the case.
    9 all welded up and paint is drying.
    all in all it didn't cost me anything and the awning is nice and secure. Note: if I werent using the Yakima feet as intentional contact points I would gusset the brackets to eliminate any flexing.
    I have more images at Expedition Ops.
    Jeremy
    Expedition Ops Outfitters
    Follow us on Facebook
    '97 LX450 with a couple goodies added on M416 trailer modified for 6'3" RTT when parked.
  2. #2
    Equipt's Avatar
    Equipt is offline Overland Training Alumni
    Sponsoring Vendor
    Supporting Sponsor Presenting Sponsor of Overland Rallies & Workshops
    Overland Certified OC0018
    Join Date
    Jun 2006
    Location
    SLC, UT / Prescott, AZ
    Posts
    951
    Hey Jeremy,
    Great idea for the awning mount. Quite unique and it looks like they are pretty sturdy. Mounting awnings to Thule or Yakima bars is pretty tough, regardless of whose awning it is. Congratulations on a great job.
    cheers,
    Paul May
    2013 Toyota Land Cruiser 200 Series, slightly modified
    2017 Toyota Tundra, slightly modified
    2004 Toyota Tundra, slightly modified
    1976 Toyota FJ40, really messed with
    2007 AT Chaser, version 2.0
    Owner, Equipt Expedition Outfitters
    801.703.1026
    866.703.1026
    www.Equipt1.com
    Paul@Equipt1.com
  3. #3
    Join Date
    Mar 2009
    Location
    MPLS, MN
    Posts
    318
    Thanks Paul,
    I figured not too bad for not needing to go to the steel yard or hardware store once. Like I said, I just followed the smart design that Eezi-Awn had.
    Jeremy
    Quote Originally Posted by Equipt View Post
    Hey Jeremy,
    cheers,
    Jeremy
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
