Page 1 of 95 1231151 ... LastLast
Thread: Building your own canopy/camper.
  1. #1
    Join Date
    Sep 2010
    Location
    Copenhagen and B.C.
    Posts
    4,396
    Default Building your own canopy/camper.
    Building your own canopy/camper is easier than you think. You just have to have some time,basic hand tools and skills, and some money. I looked at used campers for my truck and they were $3000 plus, and then i would have to modify them to suit my needs. I came to the conclusion that it was easier and better to build my own.
    First you have to find out what you need. I am a carpenter that usually works alone, so I needed something that would be easy to load heavy tools and lumber. I also needed a sleeper so that I had a fast place to catch a nap after work. Thus i decided a full standing height inside with an area for a bed over the cab of the truck would be perfect.
    Here you can see the box I made of 3/4pressure treated plywood with 45degree gussets screwed and glued into the bottom of the box and under the side of the shelf that goes over the pickup bed. There is a hole cut out to access the cab through the rear slider window. I assembled the box on top of the pick-up bed so that I had easy access to glue and screw all joints together. After it was easy to drop the box into the bed with 2 men. Yes, pressure treated is real HEAVY!
    Here you can see the basic set up. Pressure treated 3/4 ply up to cab height. The steel studs and the 2/4 studs are flush with the edge of the plywood so you can add a covering later. Steel studs that are double up inside each other horizontally on the top
    This shows the view from the back. The big opening is for a ramp that is hinged on the bottom and folds down much like the drawbridge of an old castle. Inside you can see how i just built a wall on top of were the 3/4 treated plywood stops, that is flush with the outside edge of the ply. The cross members supporting the horizontal steel studs are a 4 pack of 2by4s.
    This gives you an idea of the vertical and horizontal steels studs and 2by4s.
    There is a 3/4 ply gusset at the upper part of the rounded top at the front which is flush at the outer edge with the vertical studs so that the whole side and top is ready for the outer skin.
    Here you can see the the addition of the outside aluminum sheeting. It is super thin and light weight and requires no maintenance. The aluminum sheeting is glued on.
    Here is a side view showing the angle of the canopy above the cab. Super aerodynamic and great for 4 wheeling because it is heavy on the bottom, and super light weight on the top.
    Sorry about photbucket being trash. here is an old pic...
    from imgur.com
    a trusted website....
  2. #2
    Thanks for posting up, I have wanted the back story on your camper since seeing pics of it in a few other threads. Like the aerodynamic shape in front, the way it follows the angle of the front windshield. And the big, super big panoramic type window in front. If you spend much time in it and start to get migrane headaches, shortness of breath, impotence, a tomato growing on your neck, whatever... I have heard that the pressure treated ply woods off gas some noxious and very unhealthy fumes. Keep it it mind if you start feeling funky.
    Like the angle to the back of the camper and the Chevy/GMC too. If you have any more pics of the finished camper, would love to see them. If you have done any interior finish work, although you stated it's a work camper as well. Might be a shell. Exterior shots are good too though.
  3. #3
    Join Date
    Sep 2010
    Location
    Copenhagen and B.C.
    Posts
    4,396
    Thanks for the heads up about pressure treated wood Terrainist. In retrospect I think it would have been better to use ordinary plywood and then paint it or cover it with some thin aluminum. It does seem that now after 5 years the treated would is trying to eat its way through the thin aluminum covering. The big window in the sleeping area is a sheet of plexiglas. The inside is insulated and then covered with moisture resistant drywall. I think that if I were to build another one i would use a light wood veneer but I was thinking fire resistant when i built it.
    This show just how easy it is to unload and load your gear. If I made the ramp stronger I could probably ride a motorbike up the ramp.
    Here is a pic up by the Canadian Rockies.....
  4. #4
    Thanks for the photos. Something about the last one that is really cool, maybe it's the angles and the uniqueness of the woman. Nice photo.
  5. #5
    Join Date
    Sep 2010
    Location
    Copenhagen and B.C.
    Posts
    4,396
    Thanks Terrainist. I too enjoy the unique woman, and I would have to agree with you that pics with nice angles are interesting.
    Here you can see the Canadian Rockies again with some nice angles.
    I think this picture has exceptional angles too.
  6. #6
    Join Date
    May 2010
    Location
    Northern Utah
    Posts
    23
    Its definitly a unique build. Looks like it works out well for what you need. How heavy is it? Just curious
  7. #7
    Join Date
    Jun 2009
    Location
    northeast coast
    Posts
    1,930
    hope you don't mind; i just linked this thread here: http://www.mrsharkey.com/forum/vwtp.php?p=9712#9712
  8. #8
    Join Date
    Sep 2010
    Location
    Copenhagen and B.C.
    Posts
    4,396
    Turbo, I have really know idea how heavy the canopy is. But take 4 sheets of pressure treated 3/4 ply, 20 2by4s, 20 steel studs, 3 sheets of drywall, thin aluminum for the sides and thicker 3/16 aluminum for the top, and some insulation and then you get the idea. Cant be too heavy. You can see from the second pic in the first post that the springs hardly sag at all. Although they certainly are sagging in the last pic in the first post due to heavy cargo weight. Since then they have been replaced.
    South, there is no problem with posting the thread on other sites as long as this site thinks it is ok. If someone gets the inspiration to build something from what I did, then the more the merrier! Just remember to bolt the canopy through the frame like I did or it might get lost!
  9. #9
    Join Date
    Jan 2007
    Location
    Racine WI
    Posts
    350
    The aluminum trim I use for trimming out houses has a caution on the box to not put it over treated wood.
    Quote Originally Posted by chilliwak View Post
    Dave Bybee
    ________________________________________
    If you use it and enjoy it, doesn't matter how much it costs. If it sits around never getting used, doesn't matter how good a deal it is/was.
    2017 Ram 2500 crew cab diesel with factory air suspension
    1986 Avion 30' Travel Trailer
  10. #10
    Join Date
    Sep 2010
    Location
    Copenhagen and B.C.
    Posts
    4,396
    Good point Kilroy, I do not think pressure treated wood and aluminum is a good idea! But even still, it took 5 years to cause a problem....
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
