Thread: fuel can mounts
  1. #1
    Join Date
    Nov 2010
    Location
    Santee, CA.
    Posts
    180
    Arrow fuel can mounts
    I was at ORW in El Cajon today and I saw these 5 gal fuel cans with rack mount...looks interesting.
    http://pu-products.com/qwik_rax.htm
    Dwight
  2. #2
    Join Date
    Feb 2006
    Location
    Prescott, AZ
    Posts
    1,323
    The mount and mating jug are very nicely done. The jugs however are not CARB compliant. Their website says "*Not to be used as a fuel container in States with Air Resources Board Restrictions". CARB restrictions were adopted by the EPA and now apply to all 50 states.
    Since January of 2009, the EPA has required all portable fuel containers to possess an automatic closure spout; this means that when fuel is not being poured out of the container, the container must automatically close itself. Fuel containers must also be made of a lining that is resistant to gases flowing out of the container from the fuel. Emissions must be no higher than .3 grams per gallon per day. Containers must also have child-resistant closing mechanisms.
    http://Read more: EPA Fuel Container...#ixzz175TnUbm9
    That being said, an awesome water container no doubt!
    Mario Donovan, Trailer & Vehicle Builder and Traveler.
    '17 Dodge Ram 2500 6.7, AT Built with Habitat, 12K+ miles and counting...
    '08 Dodge Ram 2500 6.7, AT Built with Four Wheel Camper Flatbed, 160K+ miles and counting...
    '12 JK Rubicon 3.6 w/ Habitat, self contained, 120K+ miles, retired.
    '92 Jeep MJ 4.6, 371K+ miles of dust & joy, retired.
    "No matter where you go, there you are"
    www.adventuretrailers.com
    ATOverland
  3. #3
    Join Date
    Nov 2010
    Location
    Santee, CA.
    Posts
    180
    Hey Mario,
    Can they be used for "off road use only"?
  4. #4
    Join Date
    Feb 2006
    Location
    Prescott, AZ
    Posts
    1,323
    In the following CARB document related to "Utility Jugs" I do not see any such exception allowed.
    http://www.arb.ca.gov/enf/advs/advs342.pdf
    The only mention of "off-highway" that I have found in the rule is in section 2467.3 (e) specifically related to rapid refilling devices used in sanctioned competition where there is a leak proof seal between the portable container and the tank being refilled.
    http://www.arb.ca.gov/consprod/fuel-...pfcreg2005.pdf
    The following link lists specifically which portable fuel containers that are compliant with the rules
    http://www.arb.ca.gov/consprod/fuel-.../pfc/eo/eo.htm
    AT is sensitive about compliance issues. We know that it is illegal to sell containers represented as portable fuel containers that do not meet the rule requirement and hence choose not to sell anything other than compliant products.
    I hope you find the information helpful.
    ATOverland
  5. #5
    Join Date
    Nov 2010
    Location
    Santee, CA.
    Posts
    180
    Thanks for the info Mario!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
