Page 1 of 5 123 ... LastLast
Thread: Making a griddle. What material to use?
  1. #1
    cruiseroutfit's Avatar
    cruiseroutfit is offline Sponsoring Vendor Supporting Sponsor: Cruiser Outfitters
    Join Date
    Dec 2005
    Location
    Sandy, UT
    Posts
    8,391
    Default Making a griddle. What material to use?
    I've got a 2 burner Kamp Kitchn stove (think of an old Coleman 2 burner stove converted to propane) but I want to get rid of the 'grill' and add a permanently mounted griddle, hinged on the back so I can flip it up and light the burners and then set it back down and cool away.
    My first preference is to find an existing griddle close enough to work, even if I have to modify it a bit I'm fine with that.
    However suppose I wanted to start from scratch and build a griddle. What material would you use? I've seen cast iron, aluminum and steel options? Maybe stainless? Material specs? I've been bouncing around some pros and cons in my head for each material but the truth is I cook far more when camping then I do while home, hence I have zero long term experience and given many of you have likely worked in kitchens, resteraunts or built something similar I'd greatly appreciate your advice.
    Thinking of something like this:
    Kurt Williams
    Cruiser Outfitters
    Your original outfitter for OME - ARB - AA - Safari - Helton - Engel - Since 1992
    Join us on Facebook
    ExpeditionUtah - A lifelong project of exploring Utah
    kurt@cruiseroutfitters.com
  2. #2
    Join Date
    Aug 2008
    Posts
    188
    If weight is not that big of an issue, I would vote to go with cast iron. I have one that I purchased and I picked that one specifically because it fits perfectly on my camping grill. All I do is take the cast iron grate off and put the griddle on. Not sure what size your stove is but you might want to look at some griddles that might fit as is. Could save some time so you don't have to build it. But, that's all part of the fun for some.
    Here's the one I have and it's a little smaller than others which is why I picked it:
    Cheers,
    Salue
  3. #3
    I'm partial to stainless steel. Definitely do not go with aluminum. A fabrication shop should be able to form you up a griddle like the one you posted a pic of. Might want to have a flange formed on 4 sides rather than 3 though, and weld the corners - to keep it from warping. The thicker the better on the stainless as well. If you are going to have one made, go stainless.
    I've been thinking about having a shop fab me up a griddle as well. I can't find one in stainless. All the ones I've seen are non stick garbage. How that proliferated I'll never know. Non stick surface = junk.
    No restaurant kitchen with any sense or pride would ever cook with non stick pans. They don't last, they aren't durable enough to be cooked on commercially. So they would have to be replaced far, far too often. Not to mention the carcinogenic non stick surface coating that ends up in your food as the surface disintegrates. So if you run across a griddle to buy, don't go not stick. Stainless baby.
  4. #4
    Join Date
    May 2010
    Location
    NW Oregon
    Posts
    312
    1/4" mild steel plate, or stainless steel plate. Sand blasted to remove mill scale and roughen up the surface. Then season it a few times, like you would with cast iron to aide in non stick properties.
  5. #5
    Join Date
    Aug 2010
    Location
    Hollister CA
    Posts
    502
    Quote Originally Posted by INSAYN View Post
    x2
    A properly seasoned and maintained steel cooking surface will last forever, however stainless would naturally require less upkeep, and allow for less militant moisture abatement.
    87 Syncro
    "One often meets his destiny on the road he takes to avoid it" -Oogway
    What would Bruce Campbell do?
  6. #6
    Join Date
    Jan 2007
    Location
    LA, by the river
    Posts
    325
    When cooking on a griddle, mass is your friend. You will have better heat distribution, and not as likely to have hot spots. That is one reason that SS frying pans have not worked so well- they are often too thin. Some have a thicker bottom, and perform better, but I'll stick with cast iron.
    Commercial griddles are sold in 3/4" plate, and are milled flat. They are wonderful to cook on, but, of course, at 30 lbs/sq ft, they will outweigh your bumper! I have no experience with 1/4", but at 10 lbs/sq ft, it may still be a heavy beast. SS will be about a pound heavier in 1/4". And a lot more expensive, of course. I do not see the advantage in this application. Rust? Bacon helps most everything!
    I have seen, and handled griddles like the one pictured, but have not cooked on them. My concern is that they will not remain flat over the long term and many hot/cold heat cycles. They also seem thin to be used on what is often an undersized heat source like is common on camp stoves.
    My opinions are informed by well cooked pancakes, waffles, and eggs. Master the slow cooked pancake, and you're well on your way to getting up early just to feed all your friends.
    Dale
    You will likely find in the end, that you need to mod your truck as much as the friends you go with, so choose them carefully.
    (AndrewP)
    98 Tacoma, X-cab, purple, $10 sliders, purple,too. 235 85 16 Toyo Open Country AT, fresh body work by AZCAAROKCO rocks, trees, succulents, etc.
    04 Isuzu NPR HD, custom box
    05 KLR 650
    lotsa bicycles.
  7. #7
    Join Date
    Dec 2005
    Location
    Sandy, UT
    Posts
    8,391
    Right on everyone, thanks for the advice and suggestions, very helpful. So it seems like aluminum is a no go. Its light, its easily formed and fabricated but I don't want to deal with having to apply a non-stick or protective coating for the exact reasons Terrainist mentioned. That leaves mild steel (cheap, easily fabricated, heavy), stainless (expensice, easily fabricated, heavy) or cast iron which I guess I'll have to cross my fingers I can find that is the correct size.
    I've got a second Kamp Kitchn shipping to me now, hence the griddle need/want.
    This is the basic KK stove currently (during my propane swap):
    And here is a picture showing the KK on top of my dry foods box (propane complete)
    My first step with the new KK is converting the burners to run on standard 1-lb propane bottles similar to my first KK.
    At that point I want to ditch the grill all together and turn this one into a griddle setup as mentioned above. I plan to setup both KK's on bigger trips. While it sounds like extra packing I've got 100% of my cooking gear (sans food) in my single KK now. If I can use the back side of the 2nd KK for my dry foods, then I'll eliminate an additional box that I normally take and pickup the griddle option. I often end up cooking brekkie for 2-10 people on any given trip, in those cases the 2nd KK will come along, otherwise I still have my current setup. Clear as mud.
    I guess I need to start shopping around for some dimensions that will work for me and go from there. Thanks for the pic Salue, I traced the image back to Lodge Cast Iron Cookware, looks like they have 10 1/2" square & 3/4" depth, 16 3/4" x 9 1/2" & 9/16" depth, 20" x 10 7/16" & 7/8" depth. Camp Chef has a 13"x13", 16"x14", & 15"x16" professional w/sides. I'll need to measure mine but I'm guessing I'm more like 12" x 22".
    Kurt Williams
    Cruiser Outfitters
    Join us on Facebook
  8. #8
    Join Date
    Jan 2007
    Location
    LA, by the river
    Posts
    325
    Default Lodge Grill/Griddle Combo
    I am no fan of that Lodge pictured. Each time you turn it over, the bottom side will have your carefully managed seasoning burned off. Not such a big deal on the grill side, but don't mess with my griddle. Also, why, oh why, is branding so important that they cast in their (hard to clean) logo on the griddle?
    Lodge does, or did, make a one sided griddle. I own one, and enjoy it the times that I have been able to make use of it. If someone told me that I have a hundred pounds of Lodge, I would not argue.
    When you measure your KK, will you post the numbers? Pehaps one of us will see or have something that will work for you.
    Dale
    (AndrewP)
    05 KLR 650
    lotsa bicycles.
  9. #9
    Join Date
    Apr 2008
    Location
    Auburn, WA.
    Posts
    5,076
    I have the same Lodge one posted above, and I use use the griddle surface only.
    My Camp Chef Denali has a grill built in at the middle burner.
    I remove that when I place the griddle over the Denali which is a perfect fit for it.
    Never gave any thought about it by flipping it over you lose the seasoning, but I guess it would not apply to me since I only use the griddle surface of it.
  10. #10
    Join Date
    Oct 2006
    Location
    northern nevada
    Posts
    2,437
    Well you've gotten lots of good thoughts and I'll add mine
    Aluminum is really the best for heating quickly and spreading heat. Ditto for quick cool down. I would suggest a milspec hard anodized coating...I have made numerous items out of aluminum, anodized as above (not expensive BTW) and it works great. In fact you can buy commercial and high end cookware/pans with the same coating...so it works. I'd start, if you want to cover both burners, with 5/16" plate aluminum. You might be able to find a piece of scrap for reasonable $. Additionally its super easy to work with as far as cutting goes...
    You might contact the guys at Partner Steel. They offer three sizes of aluminum hard anodized griddles. Maybe they would make one to your size. I have one of their small griddles and it works great. http://www.riverconnection.com/partn...dle-p-280.html
    Cast iron is great too. But it would be a little high maintenance especially if exposed to moisture on the back of your rig. Rust loves cast iron...
    Stainless is a poor heat conductor. That is why all the great stainless steel pans are bonded with copper or aluminum. Won't typically rust...but by itself not fun to cook on griddle wise.
    1999 Toyota 100-Series Land Cruiser: Adventure rig, many mods
    2009 Kimberly Sports RV: Sold
    2006 Adventure Trailers Horizon: Sold
    No Espresso = Depresso
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
