Page 1 of 2 12 LastLast
Thread: Electrical Questions for My Adventure Wagon!
  1. #1
    Default Electrical Questions for My Adventure Wagon!
    Hey Guys. I have a Tradesman shell on my truck that I'm converting to a camper. I want to put an auxiliary battery back there for a stereo and some lighting. My question is how to hook it up to the truck's charging system. My concern is that I'll drain the cranking battery. I'm not sure if I need a charge controller or an isolator or what. I'd like to charge the house battery off the alternator, then have it isolated while i'm camping, so that if I have too many beers and leave music blasting all night long, I can still get the old girl started and get on my way in the morning.
    -Thanks!
    Max
  2. #2
    Join Date
    Nov 2010
    Location
    Middle of Nowhere, Outer Skin of Space Ship Earth, 1 A.U. from Sol, Outskirts of Milky Way.
    Posts
    4,979
    The simplest setup is a "split charge relay". Basically a heavy duty solenoid relay that is wired so it's activated when the key is on. All it does is tie the two batteries together and they both get charged. When the key is off, the batteries are separate (isolated).
    At the bottom of this page is a wiring diagram:
    http://www.powerstream.com/battery-isolator.htm
    The only difference between Powerstream's setup and a regular ol' split-charge relay is that the Powerstream has an extra little black box added that simply doesn't energize the solenoid until the engine battery has come up to 13.6v and stays there for 15 seconds.
    Diode type isolators (the ones with heat sinks that you see at any auto parts store) aren't great because the diode drops the voltage a bit and so the aux battery never really gets a full charge.
    I have a regular old split-charge relay in my old camper van and it works fine. Here's a lowbuck solenoid - buy one that is rated for continuous duty and which has a higher amperage rating than your alternator:
    [ame="http://www.amazon.com/Continuous-Duty-Solenoid-80AMP-12V/dp/B0028OO05W"]Amazon.com: Continuous Duty Solenoid 80AMP 12V: Automotive[/ame]
    EDIT: Also, use FAT wire to the aux battery. Skinny wire will drop the voltage and the aux battery won't get fully charged.
    Current: 76 E-250, bubble-top, self-contained|couple of old Yamaha enduros
    Previous wheelers: 41 Willys|78 FJ40|78 Bronco|84 Bronco|74 Ramcharger|78 Ramcharger|79 D150 PowerWagon|77 D100|79 D400 dually, converted to 4WD, utility bed, 10' Lance|75 Westy|69 Scout, RHD|bunch of others|bunch of bikes|couple of boats|couple of motorhomes|blah blah|so what|not my idea|just doin' what I'm told|wank wank|this space for rent|candy is dandy|but liquor is quicker
  3. #3
    Awesome! Thanks for the info. One more question: when I run the aux battery down, then start the truck and the solenoid closes, will the aux battery "suck" power from the starting battery? Thanks again!
  4. #4
    Join Date
    May 2006
    Location
    N37 33* W122 3*
    Posts
    157
    Quote Originally Posted by Starballs View Post
    yes.
    you can install a manual switch to make sure the connection is broken until the vehicle is started.
    also, you can take a hint/tip from the NLL dual battery controller in which it waits 5 minutes before the aux batt is connected to be charged. they say they do this to make sure the main batt is fully charged before "connecting" aux to the charging system.
    user TREMORS has a cool diagram. note the switch positions where the aux batt is disconnected from the charging system altogether:
    http://www.expeditionportal.com/foru...7&postcount=41
    leo d.
  5. #5
    Join Date
    Nov 2010
    Location
    Posts
    4,979
    Not enough to matter.
    I've run my aux battery down to damned near completely dead a bunch of times in the two years I've had this truck and fully dead several times (forgot and left something turned on inside when I parked it) and have never had any problem starting the truck (Ford 460c.i.) except when I also killed the engine battery by doing something stupid like leaving the headlights on.
    There really isn't any big surge from one battery to the other. If you want the full explanation and the math about why that's true, it's here:
    http://www.smartgauge.co.uk/nosurge2.html
    If you leave the two batteries tied together then the current will flow from one to the other and after some hours they'll level out - the one will come up in voltage and the other down until they are the same. But that doesn't happen very quickly.
  6. #6
    Join Date
    Jun 2010
    Location
    Seattle, WA USA
    Posts
    75
    If I understand correctly buying the isolator from Powerstream (or something functionally equivalent) wouldn't allow this right? It will only bridge the batteries together if the voltage is higher than 13.5V on the main battery side. Am I getting that right?
    Thanks,
    -Roger
    '09 Taco Beast
  7. #7
    Yeah, that's what I'm getting from it. I'm concerned because my truck has a diesel which requires the ignition to be turned on for ~10 seconds before cranking to heat the glow plugs, so something with a time/voltage delay would be nice.
  8. #8
    Join Date
    Nov 2010
    Location
    Posts
    4,979
    If the current flowing from one battery to the other was 150 amps, that would be 150 amps per hour, which would work out to 150 / 60 = 2.5 amp*hours per minute. 2.5 / 6 = .41 amp*hours in 10 seconds.
    Even if the current was 600 amps, then it would be 1.64 amp*hours in 10 seconds.
    Like I said...not much.
    But yea, the Powerstream or other such setup would be a step up over a plain old relay. Not really needed, but nice to have if you've got it. The other view would be that's an additional potential point of failure.
  9. #9
    Thanks again guys. We ended up installing a simple Perko style manual on/off battery switch that we can just switch over once the truck's been running for a bit. This brings me to fuses:
    Should we run a fuse between the main and aux battery? If so, how many amps?
    Also, we installed a positive and negative bus off of he aux battery to which all of our accesories are wired: a stereo, two flood lights outside, an LED dome light inside and a 12v cigarette lighter style outlet. Do we need a fuse betwen the aux battery and positive bus? How many amps?
    Sorry for all the questions. I'm not too electrically savvy.
    Thanks!
  10. #10
    Join Date
    Nov 2010
    Location
    Posts
    4,979
    The purpose of a fuse is to blow before the wire melts.
    The battery + in an auto isn't usually fused, but technically, it probably should be. Depends on where the switch is. If it was very close to the main battery then I wouldn't bother protecting the wire from main battery -> switch.
    If the wire from the switch -> aux battery is more than a foot or so long, then yea, I'd fuse it. The size of the fuse depends on the size of the wire you are protecting. Use a 30a to protect #10, 40a for #8, 50a for #6, etc.
    There really should be a fuse between the aux battery and the bus bar. Again, the fuse should be sized to protect the wire. But if the run is really short (like under a foot), and all the circuits tapped off the bus bar are fuse protected, then you can probably get by without it.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
