Page 1 of 4 123 ... LastLast
Thread: Best tire carrier spindles
  1. #1
    Join Date
    Apr 2010
    Posts
    168
    Default Best tire carrier spindles
    Okay, I am still in the middle of a roof rack build but let me just say that having access to a welder is convenient but also hurts the wallet(not as much as buying ready made parts tho) haha What is the best spindle assembly? I am only seeing the IPOR spindle as the only option? I am making what you can call a rear bumper in some way haha But I am just trying to get rid of the rear tupperware plastic bumper and mount a spare tire carrier!
    Thanks in advance guys!
    -LD
    Edit: As I find spindle options, I will post them
    Competition4x4(1750 # rating)-$85
    http://www.comp4x4.com/tire_carrier_hinge_kit_2000.html
    Iron pig offroad(no load rating)-$48.75
    http://www.ironpigoffroad.com//index...products_id=74
    AtoZ Fabrication
    Tire Carrier Swingout Heavy Duty Hinge Kit - $49.95 (1000lbs rating)
    Tire Carrier Swingout Mega Spingle Hinge Kit - $69.95 (1800lbs rating?, not clear in description, only says 80% stronger)
    http://www.atozfabrication.com/store...Hinge-Kit.html
    4x4labs (3500# rating)-$95
    http://www.4x4labs.com/products/rear...duty-spindles/
    UZJ100.305's.Nitto TG.TJM T3C.55w HID kit.Safari Snorkel.JL audio subwoofers.Pioneer AVIC head unit.Bumpitoffroad Diff drop.
  2. #2
    Join Date
    Jan 2009
    Location
    CO
    Posts
    81
    I can't vouch for one over the other, but I came across this spindle during my research in the past. It's just another to add to your list.
  3. #3
    Join Date
    Jan 2010
    Location
    Central Coast of CA
    Posts
    614
    Quote Originally Posted by brasskey View Post
    I helped a buddy build a bumper for his camper van with these (1000lbs rated kit). Very heavy duty, and IMO seemed plenty overkill for a spare tire swing out. The were very high quality, and installed painlessly. He ended up doing a swingout on each side. One a spare tire and the other was a storage box. Good luck on the build.
    The Rig: Early 1999 Ford F-250 7.3L CC 4x4 (Build Date-02/98) - 217,xxx miles
    DIY Intake with S&B Filter, FBD 4" Exhaust, leveling kit, 285's, Mag-Hytec Diff Covers, 203* thermostat, CCV Mod, DP-Tuner, and Bilstein 5150's
    The Campers:
    1990 FWC Hawk. In the process of a refurb!
    1989 Skamper 0S06 Sold, Adios Amigo
  4. #4
    Join Date
    Apr 2010
    Posts
    168
    Quote Originally Posted by SLO_F-250 View Post
    Thanks for the help guys! @SLO_f250: DO you happen to have pictures and a writeup on your buddy's bumper buildup?
  5. #5
    Join Date
    Nov 2010
    Location
    Middle of Nowhere, Outer Skin of Space Ship Earth, 1 A.U. from Sol, Outskirts of Milky Way.
    Posts
    5,314
    Current: 76 E-250, bubble-top, self-contained|couple of old Yamaha enduros
    Previous wheelers: 41 Willys|78 FJ40|78 Bronco|84 Bronco|74 Ramcharger|78 Ramcharger|79 D150 PowerWagon|77 D100|79 D400 dually, converted to 4WD, utility bed, 10' Lance|75 Westy|69 Scout, RHD|bunch of others|bunch of bikes|couple of boats|couple of motorhomes|blah blah|so what|not my idea|just doin' what I'm told|wank wank|this space for rent|candy is dandy|but liquor is quicker
  6. #6
    Join Date
    Aug 2010
    Location
    Pueblo, Colorado
    Posts
    104
    I have two of the 1000lb spindles from AtoZ on my rear bumper. One for the spare (35" on a steel wheel) and the other for a gas can carrier, (holds 4 scepters). I am very happy with them. Very high quality steel and the kit comes with everything needed. Highly recommended.
    http://www.flickr.com/photos/29877403@N03/
    '01 Dodge 2500 CTD, mostly stock.
    "whether you think you ‘can' or you think you ‘can't': either way, you're right." Henry Ford
  7. #7
    Join Date
    Mar 2009
    Location
    Arizona Territories
    Posts
    489
    Been through this before. A trailer axle/spindle WILL break. Just a matter of time. As I understand it, the problem is welding it and changing the heat-treat. Folks who make a living off of selling these will deny it, but I have seen enough of them go south. They will break.
    The ones with the support arm the comes up alongside are another possibility, but from a structural standpoint dont add a whole lot of additional strength. To me, ball bearings are silly on something that moves 90-120 degrees and only a couple times a year. But it is a nice touch. I recommend you take as much load off of the hinge in the closed position by supporting the arm on a delrin pad under the tire.
    Might want to look here;
    http://www.expeditionportal.com/foru...ad.php?t=36482
  8. #8
    Join Date
    Oct 2008
    Location
    Roanoke, VA
    Posts
    654
    I used this one in my rear bumper build: http://www.emsoffroad.com/store/inde...roducts_id=182
    I don't have a whole lot of time with the product yet, but so far it's held up wonderfully.
  9. #9
    Join Date
    Apr 2010
    Posts
    168
    Quote Originally Posted by shogun View Post
    Awesome! Thanks, thats a helpful thread
    Quote Originally Posted by JamesDowning View Post
    What size spare are you running?
  10. #10
    Join Date
    Oct 2008
    Location
    Roanoke, VA
    Posts
    654
    It's a 32". I'll be swapping to a 33" soon.
    I have 5 gallons of gas, the 60 lb tire/wheel, and the hi-lift mounted to it. Good amount of weight in total.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
