Page 1 of 2 12 LastLast
Thread: Radiant barrier in a metal cargo van.
  1. #1
    Join Date
    Jan 2011
    Location
    Idyllwild Ca
    Posts
    757
    Default Radiant barrier in a metal cargo van.
    Shortly I will be insulating my Chevrolet Astro van. I plan to paint the back first where the metal is scuffed up and gouged. Before I add my cotton insulation I want to add radiant barrier. But I have a few questions I am hoping you guys can help with.
    Should I go with single sided reflective facing outwards radiant barrier or a double sided radiant barrier that faces inward. I know inward facing radiant barrier will help in the winter, but won't heat coming in from my windows and windshield get trapped inside in the summer too?
    Secondly I am stumped on how to adhere the radiant barrier to the walls. I know there are some eco friendly spray adhesives but I would prefer a mechanical method of installing the radiant barrier if possible, would drilling it into the walls with self drilling screws work?
    How about if I install it onto the backside of my wood paneling facing outward over the cotton insulation. Would it reduce the effectiveness of the radiant barrier?
    Thanks.
  2. #2
    Join Date
    Jun 2009
    Location
    northeast coast
    Posts
    1,399
    ideally the barrier will have no penetrations. that being said, it would be an easier application if you could cut the panels and then attach (3M spray) the vapor barrier to it. i was always led to believe the barrier goes on the warm side of the insulation. i don't think the material matters much as long as it is vapor impermeable.
    if you can add a wood strip (even 1/2" thick) to the van's ribs with a strip of foam tape between it and the metal rib, and then screw your panels up with screws too short to penetrate the strip, you will have elimenated a cold bridge and source of moisture condensation.
    please post progress pictures
  3. #3
    Join Date
    Jan 2011
    Location
    Idyllwild Ca
    Posts
    757
    By vapor barrier you mean the radiant barrier, right?
    So you are suggesting I attach my radiant barrier to the back of my plywood paneling with some adhesive spray, then attach my wood paneling to the van avoiding drilling into the metal ribs themselves.
    I don't really see the point of the last step. I am trying to insulate as best as possible, not create an impermeable fortress. Does drilling through the wood paneling, insulation, and radiant barrier into the metal ribs do something I am unaware of?
    Why not just get a staple gun and attach the radiant barrier to the wood paneling that way, then just drill it directly to the metal ribs?
    If I am going to go through the hassle of gluing it to the plywood panels I might as well glue it directly to the sheet metal, right?
  4. #4
    Join Date
    Jan 2011
    Location
    Idyllwild Ca
    Posts
    757
    I've been doing a bit of research on radiant barrier. I assumed radiant barrier would work in my application because I saw a lot of van dwellers using radiant barrier in their conversions. Radiant barrier does not work without an air gap. Plain and simple.
    The way I was planning on using it would be an utter waste of money. Gluing it to the wall and the smooshing the insulation and plywood paneling over it would actually make my van warmer.
    I've been looking at foil faced bubble wrap that has it's own air gap recently but I need to do some more research. If anyone has any info on this stuff feel free to chime in.
  5. #5
    Join Date
    May 2010
    Location
    Park City, UT
    Posts
    360
    You might want to check out a product called Insul-tarp. It is a radiant barrier Designed to work without an air gap. It is cost effective And can be sandwiched With other insulation.
  6. #6
    Join Date
    Jan 2011
    Location
    Idyllwild Ca
    Posts
    757
    Quote Originally Posted by NeverEnough View Post
    Seems like it's designed to be used under concrete. Not sure it would work for my application.
  7. #7
    Join Date
    Oct 2010
    Location
    Fairbanks,Alaska
    Posts
    132
    At Lowes they sell spray foam called "Froth-Pak". I used it in 2 of my company vans. Up here in Alaska we can get some seriously cold temps. Use duck tape and some masking for anything you dont want foam on. Be careful because the the foam expands alot..... a little goes a long way. The kit runs a couple hundred bucks but it is WELL worth it. Once your done foaming,...trim off any excess and install any interior panels that you planned on.
    Chase your dreams........ Never stop........
  8. #8
    Join Date
    Jan 2011
    Location
    Idyllwild Ca
    Posts
    757
    Well, I've already got insulation. Plus, that stuff isn't intended for use on vertical surfaces.
    I do wonder if I need some kind of vapor barrier though.
  9. #9
    Join Date
    Oct 2010
    Location
    Fairbanks,Alaska
    Posts
    132
    Quote Originally Posted by Basement Yeti View Post
    We must be talking about 2 different things..... That foam is designed to go anywhere.... vertical, horizontal, overhead, etc. It's primary application is residential. It's not like the little cans of "great stuff" that takes around an hour to cure. The stuff I'm talking about is cured within minutes of being sprayed.
  10. #10
    Join Date
    Jan 2011
    Location
    Idyllwild Ca
    Posts
    757
    Hm, maybe I pulled up the wrong product when I searched.
    This polyethylene expanding foam acts like a vapor barrier too, because it doesn't hold moisture like cotton and fiberglass batting, right?
    I already bought my cotton insulation, even if I didn't the toxicity of this stuff is a concern. It out gasses chemicals for such a long time. I wish they made more eco friendly versions of this stuff, it'd be ideal.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
