Getting started, pulled the wheels and hubs apart tonight, going to get new bearings into it tomorrow.
Picking up the floor next week, then will be building a temporary wood box so I can do some hauling while I figure out how I want to the bed...
Need some fenders though, have to figure that out.
EDIT : I came up with a rough estimate off 24.5" across the top, and 15.25" on each angled piece, angle is 30 from vertical.
Got the bearings repacked, replaced one set of bearings, the others seemed ok for now, also got the notch in the front of the frame patched.
The trailer came with this piece of metal welded to it, front cross member notched for clearance, not sure the purpose...
Got the 14ga diamond plate floor
and a temporary wood box so I can start hauling stuff with the trailer, also will allow me to haul home the walls once I get those bent.
