LJ /TJ Hardtop Roof Rack?
JavaDog
Does anyone have a rack attached directly to thier hardtop? I'm thinking about putting one on my LJ's top to carry clothes, skis, light stuff like that. Anyone done this?
Haggis
Appalachian Ridgerunner
About a year and a half or so ago, I bought a set of Thule rails, footpads, risers and bars to mount up on my LJ's hardtop. Pretty much for the same reasons as you are thinking of, but in the end just couldn't bring myself to drill holes in my hardtop.
BIGdaddy
I think maybe garvin has a hardmount setup for their roofrack.
Having owned a kargomaster congo cage, I wish now that I'd considered what you're considering. (ton's of weight, lots of vibration, etc from the kongo.)
I'd also look into what they did with the J8, with a very low profile roofrack that connected to a hardened/reinforced set of roof ribs on the inside.
further still definitely look at the bajarack and a set of thule surface mounts. very light, strong rack and you can't beat thule or yakima for quality.
NOMADIC_LJ
I would worry about stress cracks to the fiberglass. It's not designed to carry ANY weight so even light weight will affect it. Just food for thought.
jeffy
I don't have a LJ/TJ but I do have a rack mounted to my YJ hardtop. The PO installed the old Con-ferr rack which have these hinge like plates that bolt to the top. Or more precisely though the top. There are grommets on the inside and probably the outer side as well. I've seen no leaking what so ever. No cracking either. The plate distributes the weight evenly. Each plate has a 2x6 footprint and there are 6 plate all together. IIRC, the top can handle around 300lbs. The majority of the weight is on the sides not the top so there is no bowing.
If I was going to buy one, (and I've thought about replacing mine), I would look at the Gavin Wilderness Track Rack (http://wildernessracks.com/roof_wild_tracks.html). They use long tracks like what you find on most SUV's. I think they look nicer especially when the rack is off. Gavin makes a rack with 4" sides as well as one with 6" sides. The rack measures 48"W x 60"L. not sure what the weight rating is but I'm sure it's more then the top can handle
College Kid
Hi have a Thule set up on my TJ, I don't carry much weight up there. but I do run a ski box and a ski rack a the same time. Box is for Boots, poles, ski cloths, and carry 2 pairs of ski's or 2 snowboards no problem. Although I have I do notice side winds more I havn't noticed any adverse affects.
jrueppel
I mounted Yakima rack rails on my JK Hardtop. 3 years later would still totally recommend it to anyone. Very easy to do. Yes a little scary to drill the first hole but it's worked out great. No leaks, easily carries the weight. Wind noise goes up a bit, and be careful loading the rocket box with too much weight. (i.e over 75-100lbs) For the last Smith Rock trip we ended up being the support vehicle for others and pushed on the cargo weight limits. When the Road Shower was loaded up with 50lbs of water as well you could tell it. At 70mpg on the highway the back end would wallow a bit changing lanes. Nothing super scary but you could tell parking that weight up there changed the center of gravity a bit.
JavaDog
Nice, thanks for all the responses! I'm nervous about drilling the top too, but I'm going to do it. It sounds like its worked out well.
@Jeffy- nice YJ, is it spring over front / spring under rear?
jeffy
Thanks! Yes, the front sits on stock YJ leafs while the rear is on some Trailmaster 4" leafs.
Just make sure you measure twice and only drill once. Might want to start off with a smaller pilot hole and work your way up so it easier for the drill bit to cut though. The bit will have less a chance to hang while cutting as well.
hollaback55
LJ Hardtop
installed thule tracks on my hardtop this winter after much debate. has worked flawlessly with no leak issues thus far. the tracks are well made, come with rubber gasket sliders for underneath and rubber washers. some silicon around the bolts and dabbed on the holes once drilled is key.
Brazos609
I have seen Cherokee rails used on a LJ tot before but I am also hesitant to drill through my hardtop. I have a good sized Thule knockoff box from Sears on a set of Thule crossbars and QD feet that I had used previously on my 4Runner just sitting here.
JavaDog
That is it! Beautiful Jeep, and that is exactly the set up that I want. Your Jeep is now my wallpaper.:26_7_2:
hollaback55
Lj
thank you, its my 2nd LJ and built to conquor all. check out the photo album, i'll be adding to is at periodically. i'm starting a m101cdn build with a matching paint job this spring. hoping to have it ready by mid may early june.
mbauerus1
