Thread: Intermittent water at tap
  1. #1
    Join Date
    Jul 2010
    Location
    England
    Posts
    65
    Default Intermittent water at tap
    Hi everybody again,
    Whats happened here?
    Just been going over camper prior to this years camping season
    got as far as the water system,
    turned on a tap, the pump beside the water tank begin running,
    the water shoots from the tap, but instead of becoming the usual calm flow, its just spitting and intermittently coming out,
    Would that be just some air issue, or symbolic of a failed pump,
    It was in a heated workshop over the bad weather this winter, and I reckon I checked it only last month and it appeared fine
    any suggestions guys
    richard
  2. #2
    Join Date
    Nov 2010
    Location
    Middle of Nowhere, Outer Skin of Space Ship Earth, 1 A.U. from Sol, Outskirts of Milky Way.
    Posts
    4,999
    Mine does that when the water tank is low.
    Current: 76 E-250, bubble-top, self-contained|couple of old Yamaha enduros
    Previous wheelers: 41 Willys|78 FJ40|78 Bronco|84 Bronco|74 Ramcharger|78 Ramcharger|79 D150 PowerWagon|77 D100|79 D400 dually, converted to 4WD, utility bed, 10' Lance|75 Westy|69 Scout, RHD|bunch of others|bunch of bikes|couple of boats|couple of motorhomes|blah blah|so what|not my idea|just doin' what I'm told|wank wank|this space for rent|candy is dandy|but liquor is quicker
  3. #3
    Join Date
    Jul 2010
    Location
    England
    Posts
    65
    My first thought too,
    but the tanks at least half full.
    No it normally spits water for about ten seconds then calms down but not tonight sadly
  4. #4
    Join Date
    Nov 2010
    Location
    Posts
    4,999
    Well, I guess if there isn't any air getting in the line, then it must be the pump. The only failed pump I ever had, had a bad motor, so I don't know what the flow might look like if the pump part was bad but the motor keeps running.
    Does it have an accumulator tank? I guess that might cause surging if it lost pressure on the air side...dunno though.
  5. #5
    Join Date
    Jul 2010
    Location
    England
    Posts
    65
    It all 'sounds' normal beyond the fact it runs almost continually,
    The pump itself looks like a small 4" dia device attached to what looks the top of a filter.
    Perhaps I'll remove it tomorrow and look at it properly.
    Was hoping it might have been a common problem that few people would point and say 'its an air lock right there'
    for refference, do you suggest draining the system at year end
    or is that not needed?
  6. #6
    Join Date
    Nov 2010
    Location
    Posts
    4,999
    I live in the Southwest U.S., so freezing isn't an issue. If I were to store the rig somewhere where freezing is gonna happen, I would absolutely drain it AND blow it out with air...broken plumbing gets messy.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
