Destructo
Located in Bend, OR. $285
Curt Q20 5th Wheel Trailer Hitch w/ R20 Slider - Dual Jaw - 20,000 lbs
http://bend.craigslist.org/pts/5893588197.html
Used a handful of times. Like new. Perfect for short bed trucks to allow them to pull 5th Wheel trailers without hitting the cab of the truck.
http://www.etrailer.com/Fifth-Wheel/Curt/C16536.html
Call, text, or email Nate @7one9-377-8797 Thanks!!
Heavy-duty 5th-wheel trailer hitch has a dual jaw, pivoting head and color-coded lock indicator for superb safety and security. Non-binding slider ensures proper clearance during slow turns. Rails and universal installation kit sold separately.
Features:
5th-Wheel hitch mounts in your truck bed so you can tow your 5th-wheel trailer
2-Jaw locking system provides 360-degree jaw-to-king-pin contact
Less rattle and more security than slide-bar models
3-Point indicator system - color coding tells you if hitch is ready to uncouple, couple or tow
Lock indicators visible from cab
Unique spherical axial bearing allows easy pivoting of hitch head
Smooth, 360-degree movement - not just front-to-back and side-to-side tilting
Built-in cushioning absorbs road shock
Non-binding slider provides clearance required for short-bed pickup to turn safely at slow speeds
Prevents trailer from hitting the cab of your pickup during sharp, slow-speed turns
Slides smoothly on rounded, non-binding rods
Designed for use on trucks with beds shorter than 8'
Not recommended for use on truck beds shorter than 6'
Lockable handle lets you easily secure trailer to hitch with padlock (sold separately)
Short-throw, single-handle operation
Self-aligning head pivots for simple hookup
3 Lube points with easy-to-access grease fittings
2-Pin head removal makes it easy for one person to remove hitch
Included plastic lube plate lets king pin glide smoothly into hitch during hookup
4" Height adjustment
Simple installation with base rails and installation kit (sold separately)
Compatible with B&W, Curt, Demco, Draw-Tite, Hidden Hitch, Husky, Reese, and Valley above-bed base rails
Sturdy steel construction with durable, carbide powder coat finish
Specs:
Gross towing weight: 20,000 lbs
Vertical load limit: 5,000 lbs
Slider travel: 12" front to back
Hitch height: 17-1/2" - 21-1/2"
Features:
Specs:
