5x Goodyear MTR Kevlar 35x15x12.5 on Cragar Soft 8 Steelies
mmccurdy
**** TIRES ARE SOLD *****
I have a set of 5 Goodyear MTR 35's w/ Kevlar mounted up to some 15" steelies. This configuration gives you plenty of meat and a good grip when you air down. This set came off my 07 JK Wrangler.
Four of the tires have about 8k miles on them -- I got them halfway through the season last summer, so they have some trail use but they are in good shape overall. Tread is about 16/32 down from about 20/32 new (see pic).
The fifth tire (spare) is brand new zero miles.
The wheels are 15x8" steel, 5x5" bolt pattern, with 4" backspacing. They have some rock rash, but they are otherwise fine (still balance up and hold the bead, etc.) The pic below is the worst one, to give you an idea of the wear. This is the second set of tires I've had on them, so the rims are in worse shape than the tires themselves -- I'm basically just throwing them in since they're mounted/balanced already.
With the wheels, mounting/balancing, etc. this combo is around $1500 new, so I'm asking $950.
I'm in Santa Clara (NorCal). These are big/heavy so local pickup is obviously preferred. I have a truck and could deliver within reason -- PM me and we can discuss.
Note: These Cragar Soft 8 15's fit over my JK calipers just fine with no grinding required, but I've seen it where very slight grinding might be required for clearance. YMMV.
Thanks for looking...
Goldenbora
