Page 1 of 5 123 ... LastLast
Thread: The center mounted winch thread....
  1. #1
    Join Date
    Dec 2005
    Location
    Southwest Colorado
    Posts
    3,364
    Default The center mounted winch thread....
    Please post up your ideas, thoughts, pictures and info on center mounted winch systems!
    Here is a link to the Canadian patent of the Vector winch system from the Foers Ibex.
    http://brevets-patents.ic.gc.ca/opic...1/summary.html
    Here is a page with a decent explanation.....
    http://www.ebroadcast.com.au/ecars/Foers/Winch.html
    Here is a basic picture on how it works...
    Pros, Cons, thoughts and experience welcome.....
  2. #2
    Join Date
    Aug 2010
    Location
    Phoenix
    Posts
    157
    pretty interesting idea
    i have my winch on a receiver hitch and power connections both front and rear and just move my winch where i need it plus it isnt in plain sight and prone to weather when not in use.
    NOMAD INDUSTRIES
    07 FFL
    Special Operations Training Services
    www.specopsts.com
  3. #3
    Join Date
    Aug 2005
    Location
    Morrison Formation
    Posts
    4,817
    At EJS one year (~1999ish) there was a cut-up buggy Jeep there that had a front-mounted winch, HOWEVER it had the cable routing extend out of the front, port, back, and starboard side, each of the 4 cable exits had two blocks that acted as the fairlead. The bitter end was firmly attached inside to the frame via metal loops and PVC tubing. He was thus able (though I never saw it) to winch himself sideways and easily recover himself from a roll which from the looks of the Jeep happened more often than forward progress.
    Questions:
    • How would you switch to free spooling?
    • How much extra cable is needed?
    • Are you always satisfied with 1/2 speed on the front? Should it rather be mounted aft the vehicle?
    Pskhaat (Scott)
    FZJ80 über rare "Geen", cloth'd & locked
    UZJ100 "Purple Pupilator"
  4. #4
    Join Date
    Dec 2005
    Location
    Southwest Colorado
    Posts
    3,364
    While the multi-mount winch is similar in function, I have found it REALLY hard to move the winch front to back while in bad snow, ice, and mud conditions. The dang thing always seem to be on the wrong end
  5. #5
    Join Date
    Dec 2005
    Location
    Southwest Colorado
    Posts
    3,364
    The foers ibex essentially had the winch mounted just behind the rear seat. You could just hit the lever. There are parts from WARN for remote control of that function with a lever, cable, or a small air cylinder.
    You could also just power out the winch as needed if your winch would not melt the synthetic line if you where running it. Some planetary winches have brakes that are in the drum and drag when you power them out for long periods. This drag creates heat that can effect synthetic winch line.
    Basically just the length of the vehicle. You lose a bit, but not much.
    The winch is usually mounted behind the front seats with the primary line off the drum going to the rear.
    To the front with the Foers Vector it is full speed, when you use the rear as per the patent it is half speed. You can also double line the front for more pulling power if needed at half speed.
  6. #6
    Join Date
    Aug 2005
    Location
    Morrison Formation
    Posts
    4,817
    Quote Originally Posted by Metcalf View Post
    Well not necessarily true? Whichever side (fore|aft) is blocked for 1/2 speed, you'll also get 1/2 length, no?
    Pskhaat (Scott)
  7. #7
    Join Date
    Dec 2005
    Location
    Southwest Colorado
    Posts
    3,364
    sorry yes, in the rear ( per the patent ) you would only get double line and half the distance.
    You do always get double the pull force to the rear however. I can see being able to use the rear winching feature to pull trailers up to my truck or pull things onto the trailer also!
    Having a few winch extensions is usually always a good idea anyways.
  8. #8
    Join Date
    Sep 2008
    Location
    Revelstoke, BC
    Posts
    253
    Does the extra complexity of a vector system outweigh the cost & install time to a vehicle not designed from the start to have it. The Ibex has it an integral part of the vehicle so there is no real 'install' cost.
    If you look at the winch challenge vehicles in the UK, how many use a vector system & how many have multiple winches... front, rear & alot now centre exiting through a circular fairlead on the top of the vehicles roll cage.
    All depends upon what you want it to do.... is it for emergency use only or winning that next comp... and of cause how deep are your pockets..... just my 2c
    '99 Land Rover D2 Expo rig.... OME 3" lift, Ashcroft HD halfshafts & 4.11 gears & Trutracs, Tom Woods drive shafts, QT front radius arms & diff guards, 265/75x16 Toyo MT's on Mach 5's, D44 front bumper with Warn 9.5Xp winch, Greg Davis rear bumper, Home made sliders, rear storage rack with Engel fridge, tablet PC mount, Rover Racks custom Voyager roof rack & Overzone RTT www.overlandcanada.com
  9. #9
    Join Date
    Dec 2005
    Location
    Southwest Colorado
    Posts
    3,364
    I do agree that it is rather complex....
    For me it could solve a few issues.
    -A front mount winch, that would be installed in a fashion that I would like, would be very complex on my dodge. I don't like winches that hang out on big bumpers. I would have to completely replace the forward most crossmember on my dodge in order to tuck the winch back enough. This would require a LOT of work including a disassembly of the entire front end sheetmetal, cooling package, tec.
    -I don't think I would be happy with just a rear mounted winch, though the install would be pretty easy compared to the front. I could just build a mount into a new rear bumper. There is plenty of room.
    -front and rear winches for me would be way expensive. There are also some things you can do with a vector style winch system that you just can't do with regular winches.
    -I am concerned about the frame strength, but I think this could be worked around with a proper design.
    I think the vector winch system can be a very flexible winch system. Pulling from almost any angle could be very valuable in an expedition type vehicle. I tend to build just about everything myself so I don't really thing it would be THAT expensive overall....time expensive, but not money expensive.
  10. #10
    Join Date
    Oct 2008
    Location
    Roanoke, VA
    Posts
    654
    Any concern with the frames not being straight? I doubt there are many frames out there that are straight, so you'd have your rope rubbing on the inside of the frame rail. You'd need to add reinforcement in those areas for sure. I can't see using synthetic in this application for this reason, unless you could reinforce the corners with very smooth aluminum.
    One other challenge would be fishing the line through the frame to begin with.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
