Page 1 of 2 12 LastLast
Thread: Hardware advice for ladder attachment
  1. #1
    DaktariEd's Avatar
    DaktariEd is offline Expedition Portal Team 2005, 2006 Tech Course Champion: Expedition Trophy
    Join Date
    Aug 2005
    Location
    Tucson, AZ, USA
    Posts
    2,735
    Default Hardware advice for ladder attachment
    OK...I want to move my ladder from being stored inside the closed tent to outside.
    The best solution I can see is to strap it beneath the tent bottom.
    I have 1/4" bolts from the actual tent attachment to the support rails that I want to use as attachment points for black rubber or similar bungee straps.
    But I am having a heck of a time finding a tie-down anchor that will slip over the 1/4" stud and clamp down one end with a good sized ring or slot at the other end.
    Hope this makes sense.
    I've surfed quite a bit...no luck so far.
    Any ideas?
    Hold fast to your dreams.
    For if your dreams die,
    then life is like a broken winged bird
    that cannot fly.
  2. #2
    Join Date
    Apr 2007
    Location
    Hudson Valley, NY
    Posts
    131
    checkout McMaster-Carr look up P/N 12065A63
    That might do what you want it to.
    HTH
    Everywhere you go, there you are!
  3. #3
    Join Date
    Jul 2005
    Posts
    3,050
    How about Quik Fist Clamps ?
    Wil has them for sale
    I also store my ladder under the Maggiolina tent on the Tacoma - the rack has just enough space to slide it under. Sure keeps the inside clean.
    Pasquale - KE7GVY
    DesertDude Films, LLC <> DesertDude Music.com <> 110 Project Group, Inc
    "Taking the path less credentialed"
  4. #4
    DaktariEd's Avatar
    Join Date
    Aug 2005
    Location
    Tucson, AZ, USA
    Posts
    2,735
    Not quite there yet, guys...
    What I'm looking for is more like a figure 8. A small washer/hole on one end fits over the exposed bolt and a nut secures it. The other end of the figure 8 is larger perhaps, and takes the hook of the bungee.
    Does that make sense?
    The McMaster-Carr site has potential...I'm searching still...
    This diagram shows an end that would work, but I can't find that end or tie-down component...
    that cannot fly.
  5. #5
    Join Date
    Apr 2007
    Location
    Hudson Valley, NY
    Posts
    131
    McMaster has damn near EVERYTHING! Even if you don't find what you are looking for for this particular thing, Contact them and get a full paper catalog, I find that it is much easier to find things in their book than on their site. The book is 4,000 pages!!!!!! The book WILL come in handy at some point!!!
  6. #6
    Join Date
    Jul 2005
    Posts
    3,050
    I have seen something like what you describe at our local Ace hardware. It is used for a cargo tie down.
    Pasquale - KE7GVY
  7. #7
    DaktariEd's Avatar
    Join Date
    Aug 2005
    Location
    Tucson, AZ, USA
    Posts
    2,735
    I'm heading for Ace shortly....
    Gotta be there somewhere!
    that cannot fly.
  8. #8
    Join Date
    Dec 2006
    Location
    Rhode Island
    Posts
    262
    How about a large flat washer with a 1/4" hole to fit the stud. Drill a hole in the edge of the washer, and put a split ring through the hole you drilled? Secure the washer with a nut.
  9. #9
    DaktariEd's Avatar
    Join Date
    Aug 2005
    Location
    Tucson, AZ, USA
    Posts
    2,735
    I searched at Ace for quite some time...no dice.
    So I went home and opened a few of my parts bins.
    Found four 1/2" x 2" straight brackets, one hole in each end already the right size. Popped them in the vice, bent them slightly (~30˚), rounded the corners; they fit perfectly.
    Added a layer of rubber padding over the tent support bars so I won't have metal on metal, and stretched a couple of bungees across.
    Voila!
    Took me longer to search the web and Ace unsuccessfully than to do it!
    Now I think I will just replace the cheap bungees with black rubber bungees.
    that cannot fly.
  10. #10
    Join Date
    Feb 2006
    Location
    Prescott, AZ
    Posts
    1,299
    Ed,
    My suggestion would be to purchase 4 of McMaster PN 8860T82, attach them to the underside of the roof rail and use 2 shortened ratchet straps to hold the ladder in place. We have used the 8860T82 as ratchet hold downs in the back Scotty's FJ40 with great success.
    Mario Donovan, Trailer & Vehicle Builder and Traveller.
    '12 JK Rubicon w/ Habitat, self contained, 120K miles & counting
    '08 Dodge Ram 2500, build in process
    92' Jeep MJ, 371K+ miles of dust & joy, retired
    "No matter where you go, there you are"
    www.adventuretrailers.com
    ATOverland
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
