New To Me Family Land Yacht - 2002 Suburban 2500
BPMOU
Well after reading lots of threads, and asking questions about the pros and cons of the 89-91 Burb to the 96-99 Burbs I ended up with a 2002 Suburban LT 2500 with the 8.1L, and automatic transmission with 123K on the clock here in Denver.
The overall goal of the truck will be running around town for the wife and kids, and heading up to the high country on forest roads and mild trails to enjoy the mountains and do some camping. It'll also be the vehicle I take hunting. At this point it sits pretty high, and its on 245/75/16's. I am hoping to be able to go a size or two bigger without a lift. I was running Toyo MT's on my 80, but I am wondering if there is anything else out there now that may be great on road as well as in the snow and the mountains?
The vehicle shows as a AZ vehicle all of it's life, but does have surface rust on the frame and undercarriage. Nothing serious, just looks ugly. It has an aftermarket exhaust on it that's pretty rusty as well.
I had the vehicle gone over by my mechanic, and he found a few things, but nothing that looks major for a truck that cost me $5K.
Here are a couple of pics after I gave it a washing.
As of now, I need to get the baseline things taken care of. Here are the things that need to be taken care of from the mechanics inspection.
  • Oil Fill Cap - Done
  • Coolant Tank Cap - Done
  • Flush and Replace Brake Fluid - Will get done this week
  • Front Shocks Leaking - Vehicle has auto-ride and each shock is $300+ from GM. Planning to remove the auto-ride system and have the computer sent out and reprogrammed without the code to check for the auto-ride. If you switch to none OEM shocks it will cause the dash to light up like a Christmas tree. Can't decide which shocks to go with here. I was thinking Bilsteins until I read the thread about going with shocks that can be rebuilt. Lots of good ones out there, but would like to stay south of $125 per shock.
  • Trans Mount Collapsed - Getting estimate from mechanic this week.
  • Motor Mounts Torn - Getting estimate from mechanic this week.
  • Trans Oil Cooler Line Seaping - Need to figure out how to fix
  • Power Steering Hose Seaping - Need to figure out how to fix
  • Exhaust Stud Broken - Getting estimate from mechanic this week.
I am getting it detailed by a guy I know who owns a mobile detail company in a couple of weeks just to clean it up from the previous owners.
Outside of that, I am going to start getting caught up on the other PM stuff. Replacing diff fluid and having the tranny serviced/fluid swapped. I just changed the oil to the M1 High Mileage, and the Napa Gold filter. The big difference between this vehicle and the 80 Series LC that i had was the forum support. This vehicle seems pretty straight forward though.
I am trying to figure out how to determine the options on it by the VIN though.
It's got Hankook Dynapros on it right now, and they are practically new, so I will keep them on until they wear out and then switch to another tire as mentioned above, just don't know which tire yet.
Never had a vehicle that I paid cash for with no car payment, so it opens up some more options then I was able to do in the past.
Should be a pretty fun family hauler. Any guidance or things that I should watch out for etc. are greatly appreciated.
Cheers!
TRACTION
I haven't run Toyo MTs before but I can vouch for the DynaPros. I ran two sets of BFG ATs thru on my Dodge 2500 and switched to the Hankooks this last time and so far have been quite happy with them. Have done about a 1000 miles of back roads, gravel, sandstone, etc and they've done well. They're obviously not a mud tire but a great AT in my opinion.
Great luck with your new rig. :victory:
bmxdannyo
Bfg km2s haven't failed me yet. Plus I've pulled at least 3 nails out of em with out losing any air, that was over 6 months ago.
Tahoe Diesel
You stole it, for that price, congratulations!
Just a few suggestions on your check list:
Rebuildable shocks would be sweet (I got excited about that thread too), but you'd probably have to buy used to stay within budget, and then have to pay for revalving which would most likely send you far North of $125 a piece. Alternately, Bilstien 5100 for your truck can be had for as little as $65 ea. After reading many rave reviews on the 5100's I bought a set for my GM and they have made a huge improvement in the ride. Even after driving on rough trails for several hours, they do not fade. However, I'm not trying to win any races or show-off, so for casual trail driving they're just perfect for me. Based on reports from others, I expect to get at least 60k out of them. Got mine in the HD version on autopartsnetwork.com
Another upgrade I'd highly recomend is the 'Cognito Motorsports Pitman/Idler Arm Support Braces'. The steering on these GM's tends to get real sloppy, due to poorly designed Pitman/Idler (especially with oversize tires and off-roading). The Cognito kit will prolong their life greatly and keep your steering tight.
Trans/Pwr Strng lines: They all leak eventually, at the crimps. Just replace them with aftermarket brand (Gates are good). They're cheap on rockauto.com, and should last at least 60k miles. They're a pain because they allways leak, but they're cheap enough that I just look at them as a routine maintenance item. Also, check your engine oil cooler lines for leaks, and particularly how they connect to the engine block. I have no experinece with the 8.1L, but knowing GM they probably use the same stupid paper clips as my 6.5TD, to hold them in place. They are notorious for blowing out, due to weak clips = Instant loss of oil pressure! Fortunately there is a permanent fix in the aftermarket for this. Check them and let me know if you need more info. Maybe someone else here with knowledge of the 8.1 can confirm/disafirm?
Tahoe Diesel
Just to add:
Change your trans/pwr strng lines before or preferably at the same time you flush/change your fluids. If you change them after, the rubber in the old lines degenerates and can contaminate your fresh clean fluid, turning it brown, so don't do that :ylsmoke:
4x4x4doors
This VIN decoder includes Chevrolet, Saturn, GMC, Hummer, Cadillac, Buick, Oldsmobile, Pontiac, Geo, Dodge, Plymouth, Jeep, Chrysler, Ford, Lincoln, Mercury, Mazda Trucks, and Mercedes.
While we have over 210 Million VIN Numbers in our database, it only goes back to 1980 and up to early 2010. Ford, Lincoln, Mercury, and Mazda Truck matches are from 1992 to early 2009.
BPMOU
Man thanks for the great info in the last couple of threads. I really appreciate it.
I picked it up from a guy who just wanted it gone since he already had three vehicles and a motor cycle and his number 6 kid on the way. His wife wasn't goin to be working and he was just trying to pay off the loan which was 5k. I'm even more exited since I got a 3k bonus coming from something else which makes it a 2k truck to me!
I will check out those options on the PM stuff as well. I will probably just go with the 5100 an this point.
I have noticed that the steering is already a little bit sloppy will the pitman arm kit help with that or am I already past that?
My shocks up front are beat and it's a pretty bumpy ride right now so between this and the mounts that takes first priority. The 5100 at that price are right up my alley!
My goal is to get it tip top here in the next couple of months so that we can log some miles on it this fall and upcoming spring. It will probably be our road trip vehicle.
Only down side is my debit card only allows a purchase of $100 in gas! :)
TreeTopFlyer
As long as you have your bump stops right, you shouldn't have to worry too much about rebuilding and all that. My 5150s blew out because I had the bumps about an inch below the shock body and they compressed more than I thought. I have another set on right now but looking to replace them with some Kings and sell the 5150s. For the price, get the 5100s and see how you like em. Anything will be better than the OEM stuff on it right now. And 5K!!! wow great find.
goin camping
Are your front shocks tied into the Auto Ride system? I ask because we have almost the same truck (Mine is an 01) and your front end is higher than mine,
Tahoe Diesel
Couldn't say, without personally inspecting them. You need to get the front end up on on a lift or axel stands, with the suspension hanging free. Severe wear will be obvious just by grabbing the center link and rocking every which way, you'll see the Pitman and idler shafts rock with it. Ideally have someone operate the steering while observing the Pitman and Idler (KEEP HANDS WELL CLEAR!)
Cognito claim that if there's only minimal wear, their kit will bring stability back to your steering and prolong the life of partially worn pitman/idler. Personally I'd just replace the Pitman/Idler if I saw any wear. But of course funds available will dictate that. Replace with Moog parts, best quality. The Moog Idler also comes with a nifty little grease nipple extension which brings the nipple right into your wheel well opening, making it a breeze to grease, which should be done at every oil change. Without that nipple ext hose, it's a real pain to even locate the nipple on top of the Idler, let alone operate the grease gun while trying to hold the gun hose on the nipple...origami for your wrists. So being so difficult to get to, the Idler is frequently neglected, which just expedites failure. Link to Cognito kit: http://www.norcaltruck.com/shop/product_info.php?products_id=242
autopartsnetwork does free shipping on the shocks, plus if you take a little extra time to search the internet for a coupon code you'll knock another 5% off the total. That's how I got my Bilstiens for $65/ea. :)
BPMOU
I believe they are. However from my research they don't really do a whole lot on the 2500 has compared to the 1500. I will be removing it from mine and sending out the computer to remove the code that checks if the auto ride system is working properly. That's what I was mentioning in the post on your thread.
So they are the OEm shocks.
goin camping
I'll be doing the same thing when the auto system dumps.
Would you please measure your fender height from ground at the hubs for me? I'd like to know the height difference between your front and rear to compare with mine.
WonaWarrior
