Page 1 of 4 123 ... LastLast
Thread: How can I charge my trailer battery, off of my vehicle battery charging system?
  1. #1
    Join Date
    Jul 2011
    Location
    Orange County, Ca.
    Posts
    573
    Default How can I charge my trailer battery, off of my vehicle battery charging system?
    I'd like to run power wires from my vehicle battery, to my trailer, through my trailer lights wiring. I have two spare wires, through my trailer light wiring. These are 12 gauge wires and I'm sure that 12 gauge is not big enough to handle the load from the vehicle.
    Any electrical engineers know how to run a charger through 12 gauge wire?
    9/23 update - My Conclusion
    Thanks to Red_5, for posting a great solution. This seems like a great product at a great price.
    Quote Originally Posted by red_5 View Post
    From my Conqueror build thread:
    I had to build a wire harness for the truck with a 10ga power, 12ga brake control and an extra wire for a lighting relay to power the rear facing lights on the roof rack.(no factory brake control wiring or charge wiring for the trailer). I ran it through the firewall and parallel the truck's wire harness inside the pass compartment. All protected by circuit breakers @ the battery.
    That was a real chore.
    The 10ga is hot all the time, and I'm using a TOAD Charger installed at the rear of the truck (rather than on the trailer), taking power off the 10ga lead and protected by it's own 15A circuit breaker, from there to the 7-way trailer connector. I chose this option for two reasons A)It's automagic, sensing charging voltage on the vehicle side to turn it on B)It's deep cycle friendly, limiting charge current to 10A. On the trailer side, I installed a 2 wire harness directly to the battery.
    This has been working great since I installed it. Zero issues.
    http://www.lslproducts.com/ToadChargePage.html
  2. #2
    Join Date
    Dec 2008
    Location
    Sydney Australia
    Posts
    26
    Run extended Pos and Neg battery leads from your battery to the rear of the vehicle terminate in an Anderson plug.
    Run extended leads from your trailer battery up your A-frame and terminate in an Anderson Plug.
    Leave enough length for trailer movement and articulation and storage when not in use.
    Anderson plugs should be readily available in electrical hardware outlets.
  3. #3
    Join Date
    Jul 2011
    Location
    Orange County, Ca.
    Posts
    573
    Anderson plugs are a great solution, but I'm trying to avoid running heavy gauge wire.
    Quote Originally Posted by larcie View Post
  4. #4
    Join Date
    Jun 2011
    Location
    Pennsylvania
    Posts
    3,368
    My GMC 2500HD was set up at the factory with a 7 pole trailer plug.
    I wired the trailer with a eight foot 7 pole lead into a junction box on the trailer.
    When I am ready to wire the trailer for a battery charger the wire is there.
    Attached Images Attached Images
  5. #5
    Join Date
    Jul 2011
    Location
    Orange County, Ca.
    Posts
    573
    That's how I'm looking to do it. Have you found a DC to DC charger yet? I've found a cool trickle charger HERE, but it's limited to 1.5 amps. I'd like to find something that will run up to 18 amps (that's what my 12 gauge wire will handle). Have been considering a solar charger. Not even sure if I need a charger. If there's a way to limit the amps to 18, then I would just do that and let the Jeep regulator handle everything else.
    Quote Originally Posted by Mark Harley View Post
  6. #6
    Join Date
    Mar 2008
    Location
    SF Bay Area
    Posts
    1,378
    A quick google says that for a 12 gauge wire, 15 feet long, max amps is 10. At the very least you'll need a 10 amp fuse up front. (that's seems small and makes me think this may not be a good idea.) Something like a National Luna battery controller would be the "ideal" solution and they recommend 4 gauge. (16 square mm). My advice - Bite the bullet and run the heavy gauge. I did for my 2nd battery (it took all freakin' day), but it's done.
    I just remember that I did wire up a 7 pin setup, but that was to power the brakes, not to charge a battery on the trailer. Even that wire is 10 gauge.
    http://www.tandemhearts.com/
    You can't jump the track,we're like cars on a cable
    and life's like an hourglass, glued to the table
    No one can find the rewind button
  7. #7
    Join Date
    Jul 2011
    Location
    Orange County, Ca.
    Posts
    573
    Yeah, I've heard what a hassle it is. I'm planning to sell my Jeep in 6 months, so I really don't want to run heavy wire. Would be curious to see where you found 12 Gauge, 10 amps, 15 feet. I figured I could run 12 gauge, 20 feet at 10 amps on the conservative side. Interesting how different data is on this topic.
    12 Gauge, 20 feet, 10 amps
    12 Gauge, 20 feet, 20 amps
    12 Gauge, 20 feet, 24 amps
    Honestly, 10 amps is more than enough to do what I need. I'm going to head down to my local electronics store and see if they can come up with something for me.
    Quote Originally Posted by ThomD View Post
  8. #8
    Join Date
    Mar 2008
    Location
    SF Bay Area
    Posts
    1,378
    That's funny. I found my info about the 15 feet bit in the same chart you linked too. I didn't think your jeep that was that long.
    Somebody who actually knows what they are talking about will show up soon and correct me, but I thought the safety concern was "how much power will a dead trailer battery try to suck from my system?" There was a heated debate about that somewhere around, but I didn't care enough to pay attention to the "experts".
    Put a small fuse on it and if it blows the fuse, you know you need heavier wire
  9. #9
    Join Date
    Jul 2011
    Location
    Orange County, Ca.
    Posts
    573
    I'm already thinking circuit breaker, as I think I'd go through a bunch of fuses.
  10. #10
    Join Date
    Oct 2010
    Location
    Warner Springs, CA
    Posts
    107
    I hope you get some good imput from this topic, I'm planning the same project for my MB-T RTT to a Jeep TJ.
    Thanks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
