Bolt-together fiberglass Jeep-tub trailer kit
jscherb
I haven't had any real chance to use the trailer for recreational purposes yet, but today I put it to work bringing some topsoil home. I loaded it with 21 40-pound bags of topsoil (840 lbs.) and a 10-lb. bag of grass seed for a total cargo weight of 850 lbs.
The trailer tracked really nicely with that weight in it, and was extremely smooth.
I was running the 3-Axis Coupler so I could give that a good test with a full load. It's easily the quietest coupler I've ever had - no noise from it whatsoever.
jscherb
I'm telling my wife we need a 3-way coupler in order to properly haul stuff from Home Depot.
I plan to convert my yellow trailer to have a tongue receiver as well so I can use the 3-Axis with that trailer too. The 3-Axis is so quiet I don't want to ever go back to an ordinary trailer ball.
By the colour of that grass I know why you needed all those bags of topsoil :) Trailer tracks beautifully though, I wonder if the coupler would be noisier/harsher with a lighter load?
jscherb
Yup, had some bad weed grass taking over so I killed everything in the area with Roundup, this morning I spread the topsoil and planted new grass so pretty soon all will be as good as new. It was nice to be able to tow the trailer to the work site in the lawn rather than hauling 840 pounds of dirt there manually.
No, the coupler is just as quiet with a light load, I've done lots of testing of the coupler with the trailer empty. The only noise from the empty trailer is from the slipper springs when the trailer hits a bump. With a load the slipper springs are quiet but empty they make some noise. Would be nice if HF trailers had shackled springs instead of slippers.
jscherb
I've been using the 3-Axis coupler a bit, but hadn't gotten around to putting a final finish on it. Yesterday I shot the parts with epoxy primer, followed by a matte black final finish. Here's a few photos of the final end result...
loren85022
Scott, in your opinion, would the Harbor Freight frame have made the 1000 miles? I'm just trying to guage the limits of one build vs another.
Sent from my iToaster
compactcamping
loren85022, IMHO a HF frame is not up to this type of usage long-term. I would be concerned about bolts coming loose and their stiff springs. The couple of mechanical issues we had with rigs was do to bolts vibrating loose.
jgrillz94
