Thread: Replacement Axle for M416
  1. #1
    Default Replacement Axle for M416
    I'm considering a replacement axle for my M416 as I want to run 5x4.5 wheels with ~3.75" backspacing. But I have some questions.
    Looking at this:
    http://www.redneck-trailer.com/2009/A/A6-A15.pdf
    That suggests I can get the following in a replacement axle:
    1) any width I want
    2) 5x4.5 hubs
    3) electronic brake
    4) parking brake (no mention as to whether it's electric or manual)
    Theoretically, that's everything I'm looking for, but I can't find a single thread here where someone has a replacement axle with all of that. So I think I'm missing something.
    Questions:
    1) How do I determine the width I want? I have a M416 and want to run 5x4.5 wheels that match my Jeep. The backspacing will be about 3.75" and I'll run tires 12.5" wide.
    2) I know I can get 5x4.5 hubs, but can I get hubs narrow enough to fit the center bore on typical Jeep wheels?
    3) How does the parking brake work? Is it only electronic? I want a manual brake, but I can't find much information out there on the possibility.
    Finally, the linked PDF shows 4" drop axles. Is it possible to run one of those upside down and basically create a semi-portal axle? This would give me 4" of lift without running spring over. Again, I've can't find anything here discussing that, so I assume I'm missing something obvious and that it's impossible.
  2. #2
    Join Date
    Nov 2008
    Location
    Centennial, CO
    Posts
    427
    I've got the first 3 things on my axle and am happy with it running stock TJ gambler wheels with no issues. If you want to swing by sometime and check it out let me know (I'm assuming shakey on co4x4 too). I liked the parking brake idea but was running into a time crunch with mine and could not wait to figure it all out, had to go with a standard width as well but with the stock backpacking on the wheels I consider it about perfect behind the ZJ.
  3. #3
    I'll have to take you up on the offer to stop by and take a look. PM sent.
  4. #4
    Join Date
    Apr 2011
    Location
    Victoria BC Canada
    Posts
    2,339
    Be sure to check this out...
    http://www.timbren.com/axle-less1.htm
    Very compelling, extra space underneath for a water tank, spare tire etc with no axle in the way.
    2014 Ram 1500 Sport 4x4 5.7L
    2000 Jeep XJ Classic 4.0L
    1992 CDN M101 1/4 Ton ExPo Trailer
    2014 Black Rock 17B 23' Travel Trailer
    VE7RXJ
    ____=__=
    l l ,[_____],
    l---- L -[]lllllll[]-
    ()_) ()_)--o-)_)
  5. #5
    Join Date
    Nov 2010
    Location
    USA
    Posts
    608
    I'm no expert, but just today ordered an axle for a Bantam T3,
    Determined lenght of axle; pulled a wheel off, placed it face down, put straight edge across back of tire, measured from straight edge to rim/ hub face add 2" inch for frame clearance, double these numbers and add to frame/tub width.
    Assume you are refering to late model OEM Jeep rims. Not that I know of, you can get spacers so the Jeep rim would fit past the hub.
    Don't know
    I wondered about this too???
  6. #6
    Join Date
    Feb 2009
    Location
    Indian Hills, Riverside
    Posts
    295
    I resently purchased an axle for my MBT willys trailer from Redneck Trailer supplies. It has elect. brakes with a 5 on 4.5 lug patern and EZ lube hubs. I did not get the parking brake, however, I can buy the parts and add it on later (I believe it is mechanical). the part number is as follows;
    1ea. 35545E-ST-EZ 52HF x 36SC each 3.5K 545 elect. straight
    **Half Camber** EZ-lube ** double spring seats (I did this so I could do a spring over or regular axle mounting)
    1 ea. apubr-1 U-bolt kit 2 3/8" RD 1/2" U-Bolts
    The total cost for the axle and u-bolts was $293.88.
    I am using a 15 x 8" rim and 33" x 12-50 BFG 15" MT's. There is approx 1.5 to 2" of back spacing between the trailer and tire.
    I am very happy with the way it worked out.
    Bruce Norris
    2005 Limited edition "Willy's" TJ
    Rubicon Express, 4.5 inch super flex lift, Rancho Shocks, 33 inch BFG KM2's, Warn 9000 lb winch, Warn front & rear bumpers, Or-fab tire carrier
    1940's MBT Willys Jeep Trailer
  7. #7
    Join Date
    Jun 2009
    Location
    Clarkston, Wa
    Posts
    457
    Whats the lenth of of the axle that you ordered? Hub face to hub face?
    97 Lexus LX450 - Dialed in the way I like it!
  8. #8
    Join Date
    May 2011
    Location
    Ca, USA
    Posts
    403
    I just installed the same axle you are looking at. But mine is for a bantam trailer instead of a m416, which I think is 3" wider. My tread http://www.expeditionportal.com/foru...the-wife/page6
    You can see the bracket and mechanical parking brake are at the top of the axle.
    Edit: I couldn't find the info for the axle length either, so I just put the new tires under the trailer with 3/4" extra per side of spacing between the tire and trailer. Than just measured between the two wheels
    love the journey with the boxer crew!
    My vehicles, nothing is stock!
    93 ZJ 5.2 Expo rig
    06 Chevy cc sb 4x4 Dmax daily driver
    95 firebird racecar/roadracer
    94 firebird track car
    08 Malibu wakesetter VTX(for sale)
    49 Bamtam extended tongue
  9. #9
    Join Date
    Oct 2012
    Location
    Texas
    Posts
    221
    I just picked up my new axle from Redneck today. I'm going to run the same wheel/tire combo as on my jeep, so after much consideration, here's what i did.
    15" x 8" steel wheels. 3.75" of backspacing. (No, the stock take off wheels will not fit the new axle.)
    33" x 12.5" x 15" Good Year Duratracs
    3,500 LB straight axle
    57" from hub face to hub face. (The stock axle is also 57" BTW)
    5 on 4.5" lug pattern
    39" From spring center to spring center.
    Electric brakes. (no parking brake)
    Had them set it up for spring over axle. No idea what the difference is.
    New U-bolt kit
    $268 total.
    I will be installing the axle tomorrow. So, I guess I will find out then what it looks like.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
