6x14 Cargo Trailer Conversion
Chris00WJ
Im not really sure this will fit the bill of an "expo" trailer, but I hope for it to be as multi-functional as possible.
Its a 6x14 white enclosed cargo trailer with V-nose and ladder rack on top. I need to be able to haul my quad in it, and possibly a snowmobile once in a while. It will become an ice fishing shack in the winter. And it will be a camper in the summer. The bad part is it isnt light and it doesnt have great clearance.
I've got this build already started over on Iceshanty so I'll just copy and paste it here if that's alright with the moderators. The build will be primary geared towards ice fishing, but it will be built with overland expeditions in mind as well. The tow vehicle is my 2000 Grand Cherokee.
Its a 6x14' cargo trailer. 2001 model year with a V-nose and ramp door. It even had a ladder rack installed by the previous owner.
The plan is to cut some holes in the floor and mount some access hatches. Im not going to make it drop down, Im just going to use sleeves. This thing still has to pull double and triple duty as a camper and hunting shack and will see some rough mountain roads.
Enough rambling, here's the pics of delivery day. Ignore the missing bumper on the tow vehicle. It has a winch bumper being fabricated.
Someone saw me about to take a picture and had to run up to get in on it. Lol.
It has a few dents and dings, but I dont care. Its functional.
It had shelves built inside, but the quad wont fit with them in there so they were the first thing to go.
Thats it so far. I've only owned it 24 hours so far.
I picked up a small 19" LCD TV and adjustable mount for entertainment and to watch the underwater cam. That will be mounted up on the V-nose above a small cabinet. It will be a very slow build over the summer. Eventually I want to add solar under the ladder rack on the roof. Hopefully the ladder rack protects the panels without shading them too bad. Lots of plans, no time or money. Lol.
Im going to try to get to the big box store tonight to pick up some 1" insulation and then that can get started.
Got it mostly insulated. One wall, ceiling and half the other wall (the curved hard part). I'd say its 70% donebeing insulated. I needed a break from the heat though so Im done for the day.
I didnt accomplish a whole lot today, but I did do a little.
I cleaned up the garage a bit so I can find and access my tools. It is still an absolute disaster, but it will have to be that way until I can clear out a project or ten.
In the process of cleaning the garage I pulled out the old tent trailer furnace (Hydroflame) and tried to get it started up. SUCCESS! The fan works beautifully. No squeaks or squeals. It lights up without hesitation and blows nice hot air. Im super happy. Now I just need to figure out what vent kit I need and get that ordered. Im not sure how the sizing works. They seem to have 8", 10", 12" vents. Im not sure where they are taking that measurement, but Im sure I'll get it figured out.
I also started gluing in the insulation. I way underestimated how much adhesive I would need, so I'll need to pick more up. I ran out of spray foam too.
The placement of the furnace is going to be difficult. I wish I could center it up front on the V nose, but the exterior vent needs to mount on a flat surface. I might try to find a way to angle the vent and have it exit straight out one side of the V. Im no sheet metal guru though so I dont even know if its possible.
Anyways, text is boring and pictures are easier to understand. So I'll run out to the garage and snap some pics.
Ok so here's the furnace and how I'd prefer to have it located in the trailer. Ignore the mess of foam.
Unfortunately as you can see, the vent would be pointed straight at the tip of the nose. The style of venting I need is Im pretty sure similar to this:
So the easiest way to mount it I think would be like this:
This setup would allow the furnace to point away from the door (to avoid wasting heat when the door gets opened), and should push the vent far enough from the nose that it wont affect the propane tanks themselves on the tongue. Im thinking dual tanks, but I may not need two.
One of the major problems would be the face of the cabinet would be at an angle. Sure I could angle the other side and have a V shaped cabinet, much like the front of the trailer, but that creates a construction nightmare for the cabinets. It would be soo much easier to just make the cabinet flat straight across. I dunno. Maybe I'll be custom making the vent afterall.
Another problem is that would have the exhaust vent closest to the door. As much as I doubt any fumes would enter through the door, that possibility exists. And if I point it the other way as seen here:
Then the exhaust vent is opposite the door but the heat would get blown straight out if the door were opened.
Decisions, decisions!
Here's a pic of the sweet blue flame of SUCCESS!
And heres the back exhaust vent section. Rectangular top part is the fresh air intake from what I can see. The round 1.25" tube is the combustion exhaust. Ignore the wires. They were temporary for testing purposes.
There is pretty limited space on the tongue so I have to figure out where Im going to put the propane tank(s) and battery without making it too tongue heavy.
real3175
I'm planning on doing something similiar in the near future but just to haul my quads and camp in year round. Looking forward to this build!
Chris00WJ
Ignore the gaps. There will be trim applied after the cabinets etc are put in.
Now there's a blank INSULATED canvas to play with.
Chris00WJ
I purchased a couple cabinets today. Im not super happy with the layout. As you can see there is quite a bit of wasted space between the cabinets. Im not sure what to do about that. Obviously custom cabinets would be the best option, but that just isnt in the budget.
Im thinking maybe I can fit the batteries between the cabinets. Maybe arrange some sort of countertop with access and use that space for storage. Im not sure. Thoughts?
I think Im going to put a small bench basically at the same angle the sunlight is at in that photo. From the edge of the cabinet to the edge of the door. Somewhere to sit down and take your boots off when you first walk in, and extra seating if required. I'll make some cushions and a back rest and have coat hooks above it probably. Or maybe a fishing rod rack.
I still have to skin the front, but I wanted to figure out the cabinet situation first so I didnt waste wood skinning behind cabinets where you'll never see it.
cyclic
My thought......................
Place the most forward cabinet right up against the corner and then use a less deep upper type cabinet to slide up to it on the left wall. You loose much less in dead space that way.
The other option is to pull both the ones you have apart some leaving a larger space which you fill with open shelves. And giving you access from the front.
Septu
This was my thought as well. You'll lose some of the bench you were talking about... but gain more storage space. Even if you can get 8-10 inches... would open up everything back there for storage.
Chris00WJ
The cabinets cant go back any more or the quad wont fit, and the angle just didnt work at the front with the front cabinet moved over any. I tried a few different arrangements and this fit the best, so its what Im stuck with now. I actually like the arrangement and the look. I'll be cutting holes in the side of the rear most cabinet and making shelves that are accessible from inside that cabinet. I also installed lighting inside that cabinet since Im going stealth with no windows (for now).
Furnace placement issues mean I'll have to cut out and reinforce a steel stud to exhaust where I want to exhaust. More work, but it shouldnt be a huge issue since I have all the necessary tools.
I need to locate some decent distribution blocks locally. Progress will be slow for the next few days as Im back at work tomorrow, but Im hoping I can accomplish a little bit before work each day.
Chris00WJ
I havent updated this thread in a while, but I've been busy!
I started building a bench/storage area on the side of the cabinet on the front. The power converter and battery are going to live here.
I stained the cabinets and the walls and ceiling. I still have to stain the trim and a few additions, but the majority of it is stained.
The roof looks like different colors from one side to the other, but its because its still slightly wet on one side. It has evened out quite a bit now.
I got the TV mounted on the nose. Yeah, yeah...I know. But keep in mind this is an ice fishing shelter too and the underwater fish TV needs a decent screen to watch the fish on! Lol.
Now the scary part. I started building a "box" for the tent trailer furnace. It has to vent straight out the wall so sticking it in the nose wasnt possible. I figured this way it can double as a bench for fishing or drinking beer. I'll have cushions made up for the top of it too. As you can see by the break in the plywood walls, the steel stud is dead center where the furnace needs to exhaust. Figures. So out came the cut off wheel, and I cut a pretty large hole in the side of my brand new (to me) trailer.
Everything went well and the vent was positioned properly. I still have to do the final mounting of the furnace and seal the vent from the outside elements etc, but it is mostly done. That was a huge step. I still have to figure out the mounting of the propane tank(s) on the front of the nose. Its a very short tongue and the jack doesnt help matters.
The furnace mounts further back in the "box" than it looks in this last picture. But it gives you a bit of a feel for the entire layout.
Goldenbora
