jayrguidaben chevy silverado z71 build
tombodad
Duratracs are awesome. Hands-down, best all-around tire I've ever run. Great in mud, snow, road, dirt, gravel... Just wish they came in load range E in the size I need for my truck now!
jayrguidaben
Just installed the tires this weekend. Love the tires! No complains or anything. It doesn't sway on the highway at 60mph above. I little hum on the road but its tolerable. Tried different psi and 46-48psi is perfect for this truck. Sometimes i rub on a full turn while reversing.
noglejr
Hows the plasti-dip holding up? I want to do the same with mine but haven't decided which product to go with yet. Good on ya and thanks for any input.
jayrguidaben
update on my build. i'm preparing our vehicle to go to yellow stone :)
new led light bars
viair ultra duty onboaird air system
switches
jayrguidaben
all done
i used shurflo 12v Water Pressure Diaphragm Pump 4.3 L/min 1.2 GPM 35 PSI -
on the left is the release pressure for the tank and the left is for the water.
Larry
Bigassgas Explorer
Cool Silverado Jay. Love the bed system!
Did you drill holes in the air filter housing for the fuse box? That may not have been a good idea as that is the clean air side of the filter where dirt can be sucked through any mounting bolts holding the fuse box down to the air filter housing straight into the engine. You would be surprised to see how an engine can suck dirt through the tinniest of holes in the air induction piping or air cleaner housing. Might want to pull the cover off and see if there is any dirt witness tracks on the bottom side of the cover.
jayrguidaben
thank you larry but no i didn't drill a hole on the air box. i just use double sided tape. its been their for 2 years now and its holding great.
WonaWarrior
