Thread: Sit-in vs Sit on top Kayaks
  1. #1
    Join Date
    Jul 2011
    Location
    Delaware
    Posts
    23
    Default Sit-in vs Sit on top Kayaks
    Could someone help me with the pros cons of sit in vs sit on top kayaks? I would like to buy a kayak for fishing mostly, no ocean fishing mostly ponds and streams, and i will not be fly fishing, will be using spinning reels or baitcasters. thanks
  2. #2
    Join Date
    Mar 2012
    Location
    Central, Maine
    Posts
    182
    I personally have only been in sit ins but my friend uses the sit on and does fishing out of it. The sit on I would think would just be better because there more open and your stuff is all right there and you don't have to mess around with everything. I would probably go that root too. For fishing I would opt for the sit on.
  3. #3
    Join Date
    May 2009
    Location
    Vancouver Island, BC, Canada
    Posts
    1,065
    get a sit on, there are some really good fishing models around, they are easier to get in and out of and for fishing getting to your gear is easier. and they are cheaper usually.
  4. #4
    Join Date
    Jul 2009
    Posts
    2,717
    My vote is for sit on top. I have two and love them. I have three rod holders and can easily access all of my gear. If I want to get out and wade its easy to get in and out.
  5. #5
    Join Date
    Apr 2011
    Posts
    194
    Paddling and touring=sit in
    Fishing and swimming=sit on
  6. #6
    Join Date
    Jul 2011
    Location
    Texas
    Posts
    2
    Check out these!
    http://www.freedomhawkkayaks.com/
    They have outriggers to make them more stable!
  7. #7
    Join Date
    Aug 2011
    Location
    Texas
    Posts
    153
    I teach beginning kayaking classes and I own six kayaks, SOT and SIK . SOT (Sit-on-top) and SIK (Sit-in-Kayak). Depending what you are going to use it for depends on which kayak will fit YOUR NEEDS. As mentioned already - TOURING or WEEKEND Camping go with SIK (15 - 18 foot range), and for paddling around and fishing go with a SOT. If running rivers and you DON'T want to get wet, get a small 10 - 12 foot SIK with a spray skirt. For fishing and running river and you are NOT worried about getting wet , then a 10 - 12 foot SOT. Difference...the SOT are as mentioned, easier to get off and on. The SIK you have to get IN and some people with bad knee and back problems will tend to go with a SOT instead of a SIK because of the ease of use. Remember one thing...the wider the kayak, the slower but more stable.
    PM if you need further recommendations!
    JJ
  8. #8
    Join Date
    Jul 2011
    Location
    Delaware
    Posts
    23
    thanks for the help guys!
  9. #9
    Join Date
    Nov 2011
    Location
    Arizona, Oregon, Idaho and Montana, depends on the time of year.
    Posts
    290
    Have owned and used both.....currently have a folding double SIK and two open cockpit SIK
    SOT.....easy to get in and out of, even if you fall in the drink;
    Colder! You DEFINITELY will get more water sprayed on you while paddling and from wind,
    Gear is more accessible but it can get knocked out of it easier,
    Wear shorts and your legs get sunburned, so use waterproof sunblock,
    Biggest negative with the SOT is how much cold water you get splashed with....I would not use these in colder lakes.
    Best compromise......and open cockpit SIK....easy to get in and out, a bit more stable in waves and wind, good gear access, and more versatile
  10. #10
    Join Date
    Jan 2012
    Location
    Wasshington State
    Posts
    32
    Jackson makes some good fishing kayaks. check out the Big Tuna, Orion, Coosa, or the Cuda.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
