Winch Extension: Making your own, a tutorial.
Beowulf
For something fun to do and have a piece of useable kit, I decided I would make my own winch extension with soft eyes.
List of parts used:
• 7/16” Amsteel Blue
• 3/4” nylon tubular webbing
• 1” Bluewater Milspec Tubular webbing
• #15 Tarred whipping twine
• Splicing Fid
• Lockstitch Needle
• Marking Pen
• Tape
• Scissors
Step 1:
Cut the material needed for the softeyes. For extra protection I decided to double layer the eyes. Bluewater Milspec Climbing webbing was used for the outer layer. This was cut to 12” sections. The inner layer is comprised of standard ¾” nylon tubular webbing cut in 11” sections. The difference in lengths will allow the inner layer to stay nicely tucked under the outer layer making for a nicer appearance.
Step 2:
Mark your bury with a total of three Fid lengths. (Fid=21 X diameter of rope). First mark is one fid length from Bury end. I mark it with a single line. Next go two fid lengths from Mark One and make Mark Two.
Step 3:
Create your eye length. I used a length of 12” for this. Start at Mark Two and measure out your eye and make Mark Three. Diameter: 12”/3.142 = 3.82”. I mark this as Mark Three.
Step 4:
By putting Mark Two and Three together you will see the size of your eye and be able to properly note where Mark Four needs to be. Mark Four is where your Bury will exit for removal of the Fid and to a secondary taper of the rope. Make sure Mark Four is beyond the end of your bury. This can also be done by measuring out four fid lengths from Mark Three.
Step 5:
Creating the initial Taper. Start Mark One. Mark touching pairs of strands. Skip a pair. Mark a pair. Skip a pair. Mark a pair. When you have done this, pull out the marked strands. Cut them off. After that I make sure to actually retuck the cut ends so that the taper is nice and clean looking. This will allow the splice to move smoothly and prevents the cut ends from getting frayed out during the process.
Step 6:
Attach the Fid.
Step 7:
Run the webbing onto the rope. Start with the ¾” webbing. Pull it down the between Mark Two and Mark Three. Make sure the webbing is not twisted. As you can see it is twisted in the pictures. Just a simple twist and it will be nice and straight. Next repeat the process with the 1” webbing and side it over the 3”4” piece When done make sure the 1” webbing is overlapping the ¾” by ½” on both side and centered between Mark Two and Mark Three.
Step 8:
Now it is time to start the bury. Take your fid and insert it at Mark Three. Make sure you have not twisted the rope and your webbing on the eye will be nice and straight when the eye is pulled tight. Keep milking the fid down and exit at or beyond Mark Four.
Step 9:
Secondary Taper. Take off the Fid that has just exited Mark Four. From the bury end cut three single strands in a row just a few inches from the end. This is very similar to the initial taper in Step 5, but don’t skip strands. This step can be left out but I like taking the extra step.
Step 10:
Pull the bury end through until the eye comes and round the ends of the webbing touch. This is basically making Mark Two and Mark Three lay on top of each other. From this point make sure to keep Mark Two and Mark Three lined up and start to milk the outer layer of rope down over the Bury. If your Mark Four was properly marked off the bury end will disappear inside the rope. IF not you will have to pull it out. Reattach the fid and bury it again only exiting further down. You will only make this mistake once.
Step 11:
Now it is time for locking the splice. This could be done in many different ways. Standard lock stitch. Standard Whip Lock. However, I like the appearance and extra locking assurance of a Stitched Whip Lock. You will need approximately 72” of #15 Tarred Twine for this. Here is a link on how to tie this.
Step 12:
Now this step is a big one and extremely important. Go back to step one and do it again for the other end. :)
Step 13:
Enjoy your handy work. Show your kids. Impress your wife. Sadly, throw it in your recovery bag and never see it again until you need it.
Notes:
The 1” webbing came from REI
The ¾” webbing from http://www.strapworks.com
#15 Tarred Twine from Gourock. This is what comes in Viking’s kit.
http://gourock.com/mcart/index.cgi?ID=187191000&PID=IT970&code=13
NOTICE:
What ever length of extension you need, know you will need six feet more. 56’ of rope is needed to make a 50' extension with 3.82" eyes.
Extra resources:
Samson Rope Splicing Instructions:
http://www.samsonrope.com/splicing-instructions.cfm
Viking Splicing Kit:
http://www.vikingoffroad.com/produc...e-Splicing-Kit%2d-for-5{47}16"-&-3{47}8".html
Yes, we did this exact thing to the winch line on my brothers jeep when we replaced the old hook with a new Tube Thimble and Excel hook from Thor. So far it has worked like the day he bought it, except with a better hook.
The only real difference we did on the winch line, was to use a standard lock stitch instead of the stitched whiplock. This was done because right where the whiplock would have been behind the Tube Thimble would have come in contact with the Hawse fairlead. We did not want the constant rub, to wear through the whipping twine. The standard lock stitch completely disaapears into the rope.
On the Extension, wear at that location is not an issue, and I wanted to go for both strength and looks. Hopefully, one of the splicing experts like Alex at Master pull and Kris @ Kris Splicing will chime in on this.
Looks good. Glad to see you take a hands on approach and make it yourself.
Personally, I like a locked brummel for extensions. No need to whip or lock stitch. Yes, getting a finished eye with sheathing on it through the line for the last splice is a PITA, but it is possible.
In any event, use your gear proudly! It should serve you well.
Thtas very impressive, TBH when I got my Dyneema I jut put eyes in the old winch wir and keep that as my extension, but its not as easy to handle
That looks good, we don't generally use the whiplock splice because of time and looks. We want the splice to be as clean as possible with no stitching showing.
-Alex
We thought about the stitching showing as well. It is the main reason that on a winch line, we went with a lock stitch as constant wear over the fairlead would have surely frayed the twine. On the Extension, we did not foresee this actually being pulled over anything. Especially that close to the splice.
These are so easy to do, that if abrasion against the exposed Whiplock even remotely looks like it will be an issue, I will just cut it off and do do a lock stitch or even undo the entire loop and do a locked brummel.
Very nice write up. Have you done this before and tested the strength of your work?
I'll be trying this, soon.
In order to test out the strength today I decided to do a little winching. I dragged the jeep up a nice incline with locked tires and the new extension performed exactly as expected.
Just wanted to add some cost analysis.
I'm not sure how cost effective it really is, but it is fun. Plus it is good practice incase you ever snap a rope on the trail.
From Redden Marine:
3/8 amsteel is $2.11 per foot. 56' = $118
1lb of #15 Braided Tarred Twine = $15.08 only use 12' = $0.45
30' of 1" webbing from REI = 12.95 only use 2' = $0.86
3/4" webbing from Strapworks = $0.17 per foot. 2' = $0.34
Initial outlay is $146
Cost for the finished product at 50' = $119.65.
With the exception of the 3/4" webbing you will be left with enough suplies to make many more extensions at any length you want. Just need to buy more rope. You would not even remotely need to double layer the eye like it did. You would use just the 1" or 3/4" webbing.
If you wanted to use tube thimbles you can be them all over the place at different prices. The really good Tube thimbles are not cheap though.
Here are the ones I would go with. They are the large gusseted style. AMSTEEL has them for $21 each. That would be $42 on top of the $118 for the rope.
Also, I should add that for the Extension, I would use the up sized tube thimble of 7/16" to 1/2" rope just because it really allows the 3/8" to tuck in really far and keep it from harm plus offering a lager radius.
After looking at some prices it seems to be cost effective. But it is always nice to buy something that you know if CORRECT and is backed by a company that loves their products.
Masterpull with the nice gusseted tube thimbles: 50' = $237
Viking with Softeyes: 50' = $183.
Both of these come with a chafe guard. You could always add a guard on the home made version for between $0.17 to $0.43 per foot. 8' would range from $1.36 to $7.31
It is always important to follow up with the good, the bad, and the ugly after years have gone by and use.
So far these have held up great. Beside the normal use as an extension, I have used shorter versions as bridle, used one to wrap around a super old trucks metal bumper, and general abused these. So far, everything has held up. No visible degradation in the eyes or splicing area.
If nothing else, I just recommend making one for the fun of it and to practice splicing.
Bobbyjr
