95 4runner window wiring
SilverBullet
So after my doors were off for the cage install, the rear window won't go up with the tube doors on. Does anyone know which wire is the cutoff from the drivers door panel so I can jumper it?
I am having trouble getting the power window controls connected, so I was thinking about just getting some manual doors, but I need the rear to work.
Thanks in advance for any help.
Caoboy
Did you try using the key? I know I was having an issue with mine ( old soda coagulant in the switch itself) and the switch itself wouldn't work, but the keyhole switch would work. Or is it not allowing to go up because of wires not being connected?
norcalmaier
